I just stick to Dymatize Elite.
Tastes great, easy to get, enough protein in there and so on.
CBS risking buying poor tasting protein in bulk and then being stuck with it.
I'll give you some of mine if you wanna risk it ya girl :D
Define quick lol?
Did you get calcium caseinate or micellar casein? Usually the casein taste extra gunky and like crap.
calcium caseinate
Within a few minutes should be fine...Last night when I had it for the first time I put it in water on it's own first to taste it without adding chocolate WPI...It's drinkable on it's own, flavorless for the most part. I threw a scoop of WPI in after that and drank it straight away.
This morning I mixed it up and put it in the fridge for maybe 15minutes before leaving for work...When I started drinking it I tasted a hard piece and thought it just didn't mix, so I shook it, and noticed white hard pieces settle on the bottom... So yeah, drink it straight after you add the water and it should be fine
Why did you opt for the calcium caseinate over the miceller casein?
Ahh I didn't realise that it is flavourless! I guess i could mix in some Dymatize for flavour.
Not sure to be honest, it's the first time I've ever bought casein and they both seem to be the same reading the description, only the calcium caseinate has a higher protein %
Haha yeah I was trying to work that out myself. I was like the description is the same...yet they are different somehow.
Thanks for the advice, I'll try it out and see how I go.
Nothing worse than chewing on chunks of protein clumped together or sticking in your throat. Shit becomes like chewing gum. Think I'll invest in a blender when I start taking protein again.
Chunks of unmixed powder are one thing, this was solidified chunks, like a plastic texture...
    • I buy my wheel cleaner in 4 litre bottles now. Euro brakes are brutal
    • Sounds like it may all just be some baseless outrage stoked by the carexplore guy? As in the linked social media outrage on facebook just goes back to carexplore as a source again. Further shown by the council response that nothing actually has changed: "The Private Land Use Permit has been part of the Casey Community Local Law for a number of years. It's important to clarify that this permit is not new, and no changes have been made to the permit or the Local Law in relation to the permit." The full council response in Prank's link sounds reasonable to me. Saying that as someone who neither lives there nor has a front yard to call their own
    • Clutch hydraulics are also all good, looks like a brand new slave cylinder and everything bled up well. No idea what the actual clutch is, and I don't intend to pull the box off on the floor to find out, so unless we have trouble on the dyno or at shakedown that will remain a mystery for the new owner
    • Front brakes are G4 8 pot calipers over 330mm discs with braided lines. Everything looks good, pretty sure these are off my old 350. Pads are brand new and judging from gold colour are Winmax which is what I also run on my race car, Neil and I both sourced brake stuff from Matty at Racebrakes Sydney who really knows his stuff Everything has bled up nicely with all new Motul RBF600 fluid, there were 2 loose hard line connections and the calipers were new on the car so I ended up doing it 3 times but it is perfect now
    • So, starting with the rear brakes. They look like standard R33 GTST, and will need new pads shortly (less than 5mm material, probably only 1 day left). The slotted discs (probably DBA) are near new at 18.01mm and the lines are braided
