Some more protein from Bulk Nutrients turned up for me today. Got myself 4kg of vanilla and 1kg of banana (I ordered 5kg of vanilla and asked if they could sub 1kg out for 1kg of banana :D). So far the vanilla is exactly as I expected - really tasty. It's a subtle vanilla taste, like you'd just put a heap of essence into milk. As always, mixes with absolute ease.
Can't wait to taste the banana though :D
Re: bulk nutrients
Bought 1kg of chocolate micellar - tastes watered down compared to the normal chocolate WPI
1KG of vanilla wpi - tastes great.
5kg of chocolate mint - rubbish. Tastes like a chocolate shake after u brush your teeth.
FFFUUUUUUU!
^Correction: Optimum Nutrition 100% Whey Gold Standard
I bought a 2.2kg tub of this last week for the first time. I got Extreme Milk Chocolate, taste's OK I guess...but the BCAA's and Glutamine profile they put in it make's up for it :thumbsup:
Deadlifts now slotting in as a favourite exercise...feels good man. Hamstring/inner leg cramps = not so lol.
I feel the same brah. Deadlifts are win, hardly being able to walk or stand up straight for the next few hours is a little less than win...well, it certainly doesn't feel like win.
Haha my legs are f**ked today, but it feels great knowing I've activated a lot of muscle that I normally don't. Now just need to get back into the squats and I'll be set, no more chicken legs.
Try having to ride home afterwards! it's about a 3 minute chillaxed ride to my gym, nice and flat all the way.....then on the way home after legs it's like WHAT THE f**kKKK
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
