This is interesting.
The BN stuff basically has zero carbs, if it's the protein powder. One of best ratio (protein vs fillers) on the market.
I certainly don't get bloated when i was using it (been a few months now since ive even trained).
A fair few others are using it too, see what they say...
It's my 2nd batch that I've purchased from them within the past 6 months. I'm thinking my tolerance to particular foods, preservatives or SOMETHING has dissapeared. I dunno.
I got 1kg of Syntrax Matrix which I'll use and see if there are any changes.. Should last me a month.
to be continued..
BN is 27g in 30g - 90% Protein
IP SP is 31g in 40g - 77% Protein
So a bit more extras than you'd realise :)
And when I say that I mean things like Fats, Sugar/Carbs & other stuff. Sometimes they include calcium like IP SP does.
In the end it comes down to your diet and what you need. Some people want as much protein as possible as they get their other stuff elsewhere in the diet etc.
The blonde chick is nice too.. she can be the backup if required.
Lou? Yeah she's the gym manager/owner or whatever you'd call it for the place. Apparently she was in my year in highschool - she recognised me and remembered my name, I was like pinch.gif who teh fark are you? I'm stupid lol
Like I stated no fillers or stabilizers
6.8% carbs... Which is not a bad thing btw
Little bit of fat/sugar as stated above..also has added Glutimine And other Aminos...
Very good product, defiantly recommend it, actually tells you everything that's in it
People can eat all the protein they want fact is your body is only goin to use so much of it...
People fail to see the value of BCAA and other amino acids, they are just as important
Edited by GTR_JOEY
From what I understand, most beneficial supps are as follows:
1. Whey Protein
2. Creatine Monohydrate
3. Branched chain amino acids (BCAA)
4. Omega 3 fish oil
5. Nitric oxide with caffeine (promotes vascularity, 'pump', and focus)
and obviously water.
Well yes, but depends on what you want/need - as I said (twice). It's cheaper than the IP-SP - IF you want a protein only supplement.
The BN stuff has BCAA's in there, feel free to go and read up on it. You'll also see it has even more detailed listing of what is in it as well :)
Whey protein contains BCAA's, so in general you would be discussing amounts/forms of it :)
Personally I don't feel the need to take BCAA's, I've noticed very few lifters I've met actually do anything except a high-protein diet & whey.
Depends how cheap you get it for I guess, I get 10 pounds/4.55kg for 140 bucks with free delivery
Yea whey protein has bcaa but you can defiantly benefit from more.
you ll find either people don't take it cause they don't know about it, or have tried it and don't know how and when to take it
or the real big juiced up steroided monkeys that do know about it don't need it cause steroids do a better job then taking legal Aminos...
I'd BCAA are pretty important as they make up a large percentage of muscle tissue lol
Read this u might change ur mind
http://www.muscleandstrength.com/supplements/ingredients/bcaa.html
1. Whey Protein
4. Omega 3 fish oil
Wouldn't be putting creatine in front of BCAA
Was talking to a nutrition expert the other day and he reckons those pre workouts with caffeine have more cons then pros in terms of strength training
^^^^ not feeling the need to take extra aminos
Edited by GTR_JOEY
Your quoting me, not Ash :P
I'd prefer to read this article: http://blog.metaboliceffect.com/page/2/ :)
I'm just saying its not required, there's nothing wrong with supplementing. Unless your wasting too much $$$ on supplementing, which most beginners do after a visit to GNC (that includes me quite a long time ago :)).
Sweet cheers for the article.. Didnt realize the effects that BCAA's have on weight loss
Still interesting though cause as ive been taking them for quite a while now and I've been stacking on the weight..( Up from 86 to 96 in the last 6 months)... Obviously results vary on diet and types of training
I'd say a couple of that 10kg is fat I do admitt but I'm getting stronger so I'll be sticking with it as weight gain and strength is may goal atm, if I get the strength without the weight even better
Way I see it is that if it helps with recovery and gives you good lean muscle it's worth taking
Edited by GTR_JOEY
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
