While on this topic, has anyone here gotten a friend to push down (encourage the negative phase of the lift) on a bar, etc. while you try to resist? It's like super negatives lol, crazy hypertrophy results
Yep, when bench pressing on a Smith. Was crazy sore afterwards.
Not to detract anything from that monster, but how much TUT do you guys devote to squats? I go much, much slower than this guy...is it more taxing to go faster or slower? I would think the latter, given you don't have the elasticity/spring helping you out on return. I think if I was to go as fast as this guy, I could probably do more weight but would end up with some pretty bad technique. Is there an explosive benefit to doing it this fast?
Sounds good I might try that. Sounds like you'd need really good technique to pull it off safely, I can see how people might do their lower back or pull a leg muscle coming up quick from a parallel or deeper position.
yeah I go a lot slower than that... nice and controlled on the way down and then explode up... the weight will dictate how much speed you have on the way up anyway... as long as you don't 'bounce' at the bottom I think your fine
I just think head/chest up, ass/hips back first (before you break at the knees) and weight on the heels
ps. that guy is about 5'2" and 75kg which makes this even more impressive
Is the guy wearing knee wraps in that vid? can see black but not sure if wraps or just sleeves to keep the heat in.
Anyway, strong muscle is a big muscle is a fast muscle. I don't know all the correlations between TUT and bb and hypertrophy etc, but I do know when you've got big weight on the bar you're not there to f**k spiders.
I think you'll find it's the opposite - the slower you go the harder it is to move the weight because you're not recruiting as many fibres during the lift.
Also, stretch shortening cycle (css) does help out the hole (referred to as "the bounce"), thing is this guy is doing 1/4 squats so not much elastic energy being stored.
Best thing is to experiment with yourself and make your own conclusions :)
That's fairly light, but squats should be easier for short guys or people with short legs?
5'2 is short as hell and squatting would alot easier for his short little legs.. Not like us guys that are over 6 foot.. Takes twice as long to get to the ground lol
Yer, that and I was thinking longer limbs = more torque/leverage working against you when you bend your long legs.
On the topic of protein powders, do you guys drink them on your off/rest days or just on days you do exercise?
I've got some Musashi 92 on hand which is low-carb and take that if I'm in a rush and don't have time or access to protein from a whole food source on non-workout days.
And then keep the protein supps that have more carbs in them for the WO days.
Finally found out my body fat % is:
Currently 82kg at 13%BF. Also started doing deadlifts again today with 120kg x 3 being my best effort. Time to step it up
Fat flamin mongrel.
lol what gym do you go to?
Dude I suggest you do some research before posting...
"When a high dietary protein intake is consumed, there is an increase in urea excretion, which suggests that amino acid oxidation is increased.."
It depends on the types of protein you're consuming, unless you've been consuming a lot of slow-release proteins throughout the day, your overnight release won't last nearly as long as consuming something like casein before bed (4-6 hours release).
... Believe what you want (supplement packaging) but I'll take advice from a guy who has a bachelor and master of science in nutrition and over 18 years experience.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
