Hmmm, might even be best speaking to Terry about this one, I like to think i know a lot about supplements but still nothing in comparison to him. Dont want to lead you down a garden path if im not 100% correct.
All good man, appreciate the insight regardless.
lol fk off Troy ya tub of lard :P
Does anyone ever get headaches / hangover feeling from certain proteins or supplements? My favourite brand of all-in-one supplement has changed something about their mixture (hadn't ordered from them for nearly 2 years) - this one smells kind of fishy and clumps up a bit more than the previous mixture, despite the breakdown label and taste being much the same. In the first week of using it I had some slight headaches on and off, but could just be coincidence, I might have had a bug for that week.
Sounds like a bad batch and you should return it to the store Birds? Did you buy more than one tub (check the other)? If it smells fishy that's no good.
Can't say I've really had headaches from supplements, only sleep deprivation from the caffeine.
This thread is starting to look dead so thought i would add some of my progress...
Recently started a 5x5 program to change it up a bit. The idea being 5s sets of 5 reps so obviulsy heavy. Then try small prigressions in weight for the next session
The key focus for these lifts are 100% technique and full range of motion. This is important so I dont cheat in the rep just so I can say I got all my reps and it's time to up the weight next session.. Upping the weight should really only occur when all reps can be completed without a spot or maybe failing in the last rep of the last set.
I've found this routine to be pretty good, done 4 weeks now so will probably only do another 1-2 weeks before changing it again..
Some examples of progress are
Weighted heaves
Started at 10kg doing 5x5
Last session was 20kg 5x5 with a fail on the last rep of 5th set
Weighted dips
Started at 20kg
Last session was 40kg 5x5
Deadlifts
Started at 140kg 5x5
Last night did 150 5x5 (really should of done 155 I reckon but pussied out)
Barbell lung walks
Started at 50kg 5x5 (5each leg so 10 reps)
Last session 65kg 5x5
Squats would be a good one but I've revised my technique so really I've gone backwards
Edited by GTR_JOEY
What's your weight?
I'm almost there myself; couple kilos off. Granted, I only attempt the 1RM after my 6 sets (OCD thing).
Some might be pleased to know I've relaxed my philosophy on restricting what I lift in order to keep my body weight down and balance the body shape. Have let lats do what they want (haven't stepped these up for 2 years), 5th and 6th sets on pulldown are now 220 pounds instead of 200...another 30 pounds and I've cleared the whole stack teehee.
Might have to look at weighted pull ups then!
Competed at GPC Nationals about a week ago.
Weighed in at 91.4kg
Squat - 190kg
Bench - 110 kg lol
Dead - 220kg
All PBs for a proper 3 lift comp.
As single lifts, the squat was a 5kg pb, bench was 5kg under pb, dead was 2.2kg under pb.
Most importantly I didn't cripple myself.
Next one is end of August. Hopefully bench will improve if I can complete my lifting plan without elbows and shoulders falling apart.
Edited by TTT
decent lifts.
First session back in the gym for a couple weeks. Must say the lack of diet and training for the period has hurt my progress. Was much weaker then before and have noticed it in my appearance.
Not to worry, hopefully wont take me long to get back to where I was and keep on going after that.
What's your weight?
I fire the same question at you Birds, what is your weight?
Currently 80kg @ 6'3
1RM for bench is 115, done after my usual 6 set workout and taken to an inch from my chest. Tried for 120 but failed half way back up...confident I could pull it off with just a warm up and straight into the 1RM!
Can anyone here strict military press their own body weight? That would be impressive
1 rep? In front or behind neck? Doubt I could do my own weight behind neck, but again, it's an exercise I've left dorment with regard to stepping up. Might start increasing it now that I'm doing that with every other exercise.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
