Which hand is your dominant hand?
I always get a better pump in my right arm, and my right arm is stronger (dominant arm). The muscles on my right arm also look slightly better (better shape, more chiselled so to say) but my left arm is indeed bigger.
My right arm is dominant.
Both my arms are a very similar circumference (right is like 1cm bigger), but my right lateral tri doesn't look quite as big as the left.
With the coming back from being sick, I usually drop the weight to get out more reps, so i keep it to at least 8 reps for the first 2 sets if I'm doing 4 sets.
Its demoralizing as all f**k, but I don't like only doing 5/6 reps. It feels like I've cheated myself in a way...
Either way coming back from a sickness sucks. You can usually tell when you are coming down with something though, because you inexplicably drop a few reps more than usual
While we're on the topic, what do people usually do when they come back from illness / a week or two off from the gym? Regular weight and just deal with pushing out less reps of it? Or drop the weight to shoot for the regular amount of reps?
Eat... everything I can lay my hands on as soon as appetite comes back... then go to the gym with the intention of taking it easy, ignore that intention, try and lift heavy, get frustrated, leave... go home and eat more lol
Ahahahaha this made me lol. It really makes you appreciate the level you were training at prior to the sickness...puts things in perspective. Don't know how Olympic athletes do it, who are at training at the peak of their body's ability...the drop back from being sick must take weeks/months to get back.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
