Around 7k
Knew someone would be a smart-ass!
Physio told me I have bicep tendonitis... spewing. So its a few weeks to a month of legs and squats.
Any upper body recommendations that are not going to make it worse while it recovers?
Get into a solid fapping routine. 3 sets of 100 reps per arm.
What do you guys think about home made weight plates ?
I am thinking of designing some in solidworks at work and then getting them lasercut to spec.
Ideas ? Interest ?
Also considering designing my own squat rack and cutting it here.
Sounds like you'll still be able to do pushing movements so triceps, chest, shoulders should all be fine to work.
Ideas ? Interest ?
If you can get them to be the correct weight (like within a gram of each other) then it should be fine.. but also consider that buying brand new rubber coated plates which have handles built in and are the correct diameter and cost about $3 a kilo or less delivered, you'd better be making a decent saving.
As for the rack, I can find you detailed plans of a power cage if you would like.
Any idea of root cause?
My knee tendonitis is actually a combination of hamstring tightness and glute tightness, and maybe the quads are involved too. Either way, if i stop stretching / rolling for any reasonable period of time even without weights I start getting knee problems.
The physio's gave me some excercises but they never helped, it took a long time to find the cause.
Yes Please !
the weight of the barbells would be pretty close, probably not to the gram though. however I know I could make them for a lot less than $3.00 per kilo.
are you looking at making barbells or plates?
as for plans..
http://startingstrength.com/files/starting_strength_rack.pdf
I'm sure that has all the info you need.
in the end it will look like this.
http://startingstrength.com/index.php/site/equipment
Wear em loud and proud eh?
Nah, I hate that carpet burnish feeling I get from scraping the bar up against my shin. I still get it a bit in trackies, but it's not as bad. Hopefully my shin skin will start getting thicker soon.
Are people doing deadlifts on leg day or back day?
I always seem to do them on back day purely because I like to squat on leg day and I wouldn't be able to get the most out of it if I did them on the same day. I do Bulgarian/straight leg deadlifts on leg day instead which seem to be ok even after squatting.
Edited by Mitcho_7
Are you guys more oriented toward the powerlifting side of training?
I just find I struggle to get decent weight up on deadlifts after doing 4x10 of squats. Doing them on my back day seems to work better for me I think. It allows me to give them my all rather than half assing them because I'm already spent.
I was just interested to hear other people's thoughts on how you work them both into your training...
Edited by Mitcho_7
Having watched some tutorial/classroom style videos from Mark Rippetoe over the last week, I'm convinced that deadlifts are primarily a back exercise (while they do hammer glutes and hammies something nasty though)
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
