try explosive/plyometric stuff for your calves... weighted jumps, hops, sled pushing etc
Would explain why quite a few tennis players seem to have decent calves for their body size...
I would agree that it is mostly genetic. But I have also read others have had good results with using a combination of standing and seated calf raises, 3 times a week give or take. Also, to target the left/right sides of each calf, you can alternate between pressing up with the big-toe side of the foot and the pinkie side of the foot. But apparently it's not so good to actually rotate the foot (toe-in or toe-out).
Travel back in time, and find a way to be an egg in another ovary to your mums and also find a way for another person than your dad to exploded in there.
No wonder you have a 1 star rating on here..You honestly are just a dumb meat head.
Do you even lift brah ?
Daniel, you serious mate? TTT has a lot of experience...
I dont doubt that he has experience.
But his experience makes him look down upon the people who dont have as much experience.
Everyone has to start somewhere and I bet he didnt just wake up one day knowing the meaning of life
whatever you do with calves, do it until they burn, I find between 10-15 reps works well.
gaining size on your calves is difficult as TTT said, alot of it has to do with genes. With that being said mine have grown.
also what Birds said, hill runs or even just put a real heavy pack on your back 20kg+ and go bush walking, your calves will grow after a few months of doing that.
Going to read into thise explosive training for calves, will try weight jumps tomorrow though. A lot of people say just squat to get calves, but I do that 3x a week anyway and not seeing any difference really.
Dont want to end up like dis.
I'm assuming you mean genetics? I don't know, I don't really believe in that whole "I cant grow calves so it must be my genetics", they'll eventually grow with the right training, they just might take longer.
Edited by Dani Boi
Hahaha holy shit! Looks like a stiff breeze would blow him over.
I bloody love training legs.
Full range of motion needed for calves too. Mine often cramp up because they're so tight though.
of course you can improve the size and shape of your calves.
But take that guy in the picture above, he can throw everything he's got at calves, and they will grow a little and change shape a bit, but they will never look like the calves of a trucker as Birds said earlier.
your genes decide how your muscles are in regards to the width, length, where it ties in behind the knee and soleus.
depends on your make up of fast twitch or slow twitch fibres.
when it comes to calves you can improve what you have, but there will be people who have awesome calves by walking tot he kitchen and back.
Google "doggcrapp calf training"
try it out.
I strongly suggest you ease in to this and don't just go do the reps and sets suggested straight up.
I'm serious. you will not be able to walk.
doggcrapp training in general is pretty good stuff for those of you image inclined peeps.
I think higher reps ranges are the go for calves like people have said. I have crappy calves, my gastrocnemius are literally only 1/3 of the length of my shin so im never going to have big calves due to genetics. I usually pick a weight and go til failure, with both a seated and straight legged exercise . Calves would be predominantly slow twitch fibres due to there function in everyday life and your type IIa fibres will have taken on the characteristics of type I fibres if all you do is walk around.
Edited by Mitcho_7
higher reps for calves? the fckers are used to carrying your body weight for hours at a time doing god knows how many reps... you have to shock them, force them to adapt by doing something different
I have always had decent sized calves (nothing spectacular) not sure about my genetics but I've played basketball for nearly 20 years... just like tennis, basketball is played on your toes a lot and all the jumping and sprinting is demanding for the calves
This. Let the strength gains put on the kg. People get too caught up in weight figures when trying to get big, which are meaningless without BF% to back them up. It kind of mystifies me when someone says they would like to weigh xxxkg or set weight goals without knowing what they'll look like at that weight.
Also big on power to weight ratios. Putting on fat is only going to reduce this! I love being light at 79kg and benching the same (and sometimes more) than my 100kg friends.
Exactly, when I started I was the old...'I wouldn't mind being around 80 but it be muscle, not fat' Im not near there now and don't mind,
I'm still gaining strength.
Started back on deads and squats tonight after a six week hiatus (flu + cold, thanks). I decided that, rather than getting depressed over not being able to do the same weight/reps as before...or using shitty technique to obtain them...I would seize opportunity to start fresh with perfect technique and low weights.
Where I used to squat to parallel, I thought I'd give ass to ground a go at half my normal weights. My problem with squatting to parallel, has been that it's tough to judge if you are actually making it to parallel. It's also very easy to cheat, whether you are decreasing your range of motion later on in the set or involving more back muscles to help get it up (ala good mornings).
So I started with a warm up set of 10 @ 40kg. When I lifted the bar off the rack I laughed at how light it felt compared to 100kg+. In fact, the first rep felt like I had nothing on my neck. However, 10 reps later and I actually started feeling it. Up the weight went to 45 and then 50...the latter of which left my legs almost as sore as 100kg parallels did previously (probably helps that I haven't done squats for weeks).
The most satisfying thing about this experience, was knowing that my range of motion was at it's limits; that every rep in the set had the same ROM. I couldn't cheat in any way and my back stayed as straight as an arrow. The weight was also very much on my heels, where it should be. After I was done my legs felt much more comprehensively worked than parallel squatting.
Now I know the weights weren't high, but I was surprised at how much I could do considering I'm effectively doubling my ROM. I expected even half my normal weights to be a struggle and it wasn't...it just worked my legs much more thoroughly and satisfyingly - hard to explain. I urge everyone doing parallel to give it a go, I'm definitely a convert. Will be interesting to see how long it takes until I'm doing what I used to do to parallel.
Now mentally hypercritical of people doing half squats at high weights lol. Humans = hypocrites.
I remember doing 100kg to the point where you were effectively resting on maximum ROM for 3 seconds - ass on heels - and then standing back up BUT NOT LOCKING OUT KNEES. Repeat for 8 reps.
Then try to walk out of gym.
The walking part didn't work.
Legs said no.
I would love to be able to squat properly (ass to ground style), but my flexibility doesnt allow it at the moment and my right knee doesnt seem to be a huge fan of trying to go lower than parrallel either.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
