Well there are weight classes
60kg, 67.5kg, 75kg, 82.5kg, 90kg, 100kg, 110kg, 125kg, 140kg, 140kg+. You must way UNDER the weight
Our best lifters
75kg class - Emad Nayef 220kg squat, 125 bench(injured, has done 150kg) and 260kg deadlift, in competition, best total 602.5kg (35yo)
82.5kg class - Martin Nguyen 227.5kg squat, 132.5kg bench press , deadlift 272.5kg, best total 632.5kg (teen, 19)
90kg class - Max Markopoulos 250kg squat, 155kg bench, 245kg deadlift, best total 650kg (20yo)
140kg+ - Jack Pollard 280kg squat, 185kg bench, 280kg deadlift, best total 745kg 21yo)
All 4 lifters have lifted more in the gym, but these are comp results only
Sweet! Gives something to aspire to! How many years they been training for?
Well, Jack is 21, he walked into PTC on June 10 2010, it was the first time he'd been to a gym. So he squatted 300kg in a little over 2 years.
Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago
Emad did his first comp in December 2011, he had been lifting weights for football
I think there is a video on my YouTube channel of Max at 16 powercleaning 100kg@67kg or something like that, I'll try and find it
Markos dont let TTT see your post below about training at home being simple:
"Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago"
It could be misread to make us beleive that training in a gym has actually been of benefit.... *shock*.... *gasp*
Tolga knows Martins story. Martin trained at home for 3 years, when he walked into PTC at Xmas 2011, his total as we tested it was 520kg
In June 2012 he totalled 632.5kg at Nats, so 112.5kg in 6 months is good when youre already strong
Martin went from 180/120/220 to 227.5/132.5/272.5. He missed his 3rd attempt bench which he made in the gym of 140kg, so it couldve been better
He has since benched 152.5kg
Martin got strong at home, then broke the Teen 82.5kg Class WR by over 100kg when he switched to a proper PL gym
He's a great kid and an excellent dancer lol
FFS someone please ban markos... or at least stop him posting videos of skinny kids lifting more than me lol
This. My balls are being broken not having a PTC here in Canberra right now. SO MUCH WANT.
Right.
You think that if Martin trained at fitness first or your gym that he would have had the same results?
Lol
The word gym means different things to different people.
Don't try to make out that I said everyone should train at home.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
    • Does anyone know if this is off centered? Looks like it, when I indicate to go right, but turn my steering wheel slightly left it cancels (was always like that even before I started messing around with it) was wondering if anyone else has the same issue?
    • Nothing photo worthy since last update, lots of little plumbing bits for the AAC/Cold start valves, and unfortunately I still need another couple of parts for the brake booster line and the AAC into the plenum. Otherwise it all looks good to start up engine wise, onto checking the electrics/interior
