Well there are weight classes
60kg, 67.5kg, 75kg, 82.5kg, 90kg, 100kg, 110kg, 125kg, 140kg, 140kg+. You must way UNDER the weight
Our best lifters
75kg class - Emad Nayef 220kg squat, 125 bench(injured, has done 150kg) and 260kg deadlift, in competition, best total 602.5kg (35yo)
82.5kg class - Martin Nguyen 227.5kg squat, 132.5kg bench press , deadlift 272.5kg, best total 632.5kg (teen, 19)
90kg class - Max Markopoulos 250kg squat, 155kg bench, 245kg deadlift, best total 650kg (20yo)
140kg+ - Jack Pollard 280kg squat, 185kg bench, 280kg deadlift, best total 745kg 21yo)
All 4 lifters have lifted more in the gym, but these are comp results only
Sweet! Gives something to aspire to! How many years they been training for?
Well, Jack is 21, he walked into PTC on June 10 2010, it was the first time he'd been to a gym. So he squatted 300kg in a little over 2 years.
Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago
Emad did his first comp in December 2011, he had been lifting weights for football
I think there is a video on my YouTube channel of Max at 16 powercleaning 100kg@67kg or something like that, I'll try and find it
Markos dont let TTT see your post below about training at home being simple:
"Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago"
It could be misread to make us beleive that training in a gym has actually been of benefit.... *shock*.... *gasp*
Tolga knows Martins story. Martin trained at home for 3 years, when he walked into PTC at Xmas 2011, his total as we tested it was 520kg
In June 2012 he totalled 632.5kg at Nats, so 112.5kg in 6 months is good when youre already strong
Martin went from 180/120/220 to 227.5/132.5/272.5. He missed his 3rd attempt bench which he made in the gym of 140kg, so it couldve been better
He has since benched 152.5kg
Martin got strong at home, then broke the Teen 82.5kg Class WR by over 100kg when he switched to a proper PL gym
He's a great kid and an excellent dancer lol
FFS someone please ban markos... or at least stop him posting videos of skinny kids lifting more than me lol
This. My balls are being broken not having a PTC here in Canberra right now. SO MUCH WANT.
Right.
You think that if Martin trained at fitness first or your gym that he would have had the same results?
Lol
The word gym means different things to different people.
Don't try to make out that I said everyone should train at home.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
