Well there are weight classes
60kg, 67.5kg, 75kg, 82.5kg, 90kg, 100kg, 110kg, 125kg, 140kg, 140kg+. You must way UNDER the weight
Our best lifters
75kg class - Emad Nayef 220kg squat, 125 bench(injured, has done 150kg) and 260kg deadlift, in competition, best total 602.5kg (35yo)
82.5kg class - Martin Nguyen 227.5kg squat, 132.5kg bench press , deadlift 272.5kg, best total 632.5kg (teen, 19)
90kg class - Max Markopoulos 250kg squat, 155kg bench, 245kg deadlift, best total 650kg (20yo)
140kg+ - Jack Pollard 280kg squat, 185kg bench, 280kg deadlift, best total 745kg 21yo)
All 4 lifters have lifted more in the gym, but these are comp results only
Sweet! Gives something to aspire to! How many years they been training for?
Well, Jack is 21, he walked into PTC on June 10 2010, it was the first time he'd been to a gym. So he squatted 300kg in a little over 2 years.
Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago
Emad did his first comp in December 2011, he had been lifting weights for football
I think there is a video on my YouTube channel of Max at 16 powercleaning 100kg@67kg or something like that, I'll try and find it
Markos dont let TTT see your post below about training at home being simple:
"Max and Martin both started lifting at 15, so 5 years all up. Max only started powerlifting in April 2010, before that it was lifting for Soccer and Basketball, Martin simply trained at home until 10 months ago"
It could be misread to make us beleive that training in a gym has actually been of benefit.... *shock*.... *gasp*
Tolga knows Martins story. Martin trained at home for 3 years, when he walked into PTC at Xmas 2011, his total as we tested it was 520kg
In June 2012 he totalled 632.5kg at Nats, so 112.5kg in 6 months is good when youre already strong
Martin went from 180/120/220 to 227.5/132.5/272.5. He missed his 3rd attempt bench which he made in the gym of 140kg, so it couldve been better
He has since benched 152.5kg
Martin got strong at home, then broke the Teen 82.5kg Class WR by over 100kg when he switched to a proper PL gym
He's a great kid and an excellent dancer lol
FFS someone please ban markos... or at least stop him posting videos of skinny kids lifting more than me lol
This. My balls are being broken not having a PTC here in Canberra right now. SO MUCH WANT.
Right.
You think that if Martin trained at fitness first or your gym that he would have had the same results?
Lol
The word gym means different things to different people.
Don't try to make out that I said everyone should train at home.
    • My EFR 8474 Black, made 800awhp on a roller dyno. at 25-26psi. E85. Shaft speed was around 106,000rpm 1.01 rear. The rear is maxed.  6 boost Turbosmart 60mm gate 3.5inch exhaust  Head is worked to the shithouse. Bain racing. VCam. 272 exhaust. RB28 - RB26 foundation.  You have an intake issue. Start getting proper data and I mean go back to the simple things.  - Pressure test your intake - Block off the Turbo BOV, you don't need it.  - Test pressure before and after your intercooler If your head is pretty stock, that is your issue. Especially if it is NA.  Take it off and spend $10k on it.
    • Temp = -21.052 X Voltage + 114   That should get you pretty close. Calcs based on two points I could do easy calcs on (30 and 70 degrees).   It also says your sensor should only read as low as 9 degrees when it maxes out at 5V, and should hit a peak of 114 degrees at 0V... Just as a heads up if you were going really cold places, or wanting to be aware when temps really go up with it.
    • you, sir, are a prince. good on ya.
    • You're not wrong but 5W30 at 100C is like 10 cSt vs 25 cSt for 10W60. If we think in terms of viscosity margin 10W60 will probably still be ok at 130C but 5W30 is probably too little. It's absolutely shocking how hot the oil gets in something like a stock FL5 from only ~3 minutes of use on the Nordschleife. I would not risk taking a car like that to anything remotely intense without a ton of work done for cooling. Heat shielding on the manifold/turbo/downpipe, oil coolers, etc.
