Okay so not sure if the 300m rower question was serious or not because I happened to check last night at the gym, and I did 300m easily in under a minute.
Yer there is a few, there is one where i am that is an indoor one that has a water barrel thing. The WR is 14.58 for 5000m
I'm not on any protein Supp yet, I'm looking to gain lean muscle,
gaining lean muscle and not much fat is just about impossible for the normal everyday person. Sure there are some special people with great genetics but for 99% of the population who work normal 9-5 jobs its not going to happen.
now that that's out of the way, if you want to gain lean muscle and not much fat. Give up all junk food, soft drinks and any other vices that you have. Eat shit loads of protein with every meal and no carbs after 7.
for a protein shake that has very little carb try Ultimate Nutrition Pro Star 100% Whey. Mix with cold water and it goes down alright.
Also anyone tried Muscle Meals Direct? Have read good things.
Yer I know about that, mainly all of it is diet.
Looking at the negative comments I guessing I put it the wrong way, I'm not aiming to get minimal body fat and skin wrapped. Im just looking to turn the fat I have into muscle and some definition.
each post seems less smart than the last.
You can't "turn" fat in to muscle, just like I can't "turn" my skyline in to a Porsche.
They are 2 different things.
Definition is also almost as retarded word as tone.
If you want your muscles to stand out more, you have to lose fat.
If you lose fat, it's very hard to keep muscles.
if you have very little muscles, then losing weight will make you look like you are soon to hit puberty
tips:
count calories, MyFitnessPal is pretty decent
diet better and smarter
train harder
HITT
I eat majority of my carbs after 7. After training. I gain lean muscle and it's not because of 'genetics'
Chew your macros.
Edited by jangles
    • E10, by very definition, has 10% E in it.
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
