A carb is not a carb. A sugar drink is not the same as a bowl of oats.
1000 calories of big m is not the same as 1000 calories of steak.
Your body utilises proteins different to sugars, and fats different to either also.
I mean, that's pure basics. Why do you take a protein shake after a workout and not a tub of lard??? It's common sense, your body uses different
macro's for different things.
And fruit is not a ball of sugar. It's natural, comes from the ground, is full of vitamins, minerals, antioxidants, fibre and is just down right good for you.
A healthy body is a happy body, and a happy body is ALOT easier to work with.
While you didn't directly say everything that comes from the ground is good for you, in certain situations in life - like when making a statement or declaration to police - this wording could be construed to mean exactly that.
A statement to police, you've got to be joking.
I was talking about fruit, you know, what you buy at a fruit shop.
Seriously, if you guys wanted to act like retards, then you'll be treated like retards.
F this i'm out
Loving 1.25kg plates...been using them to step up bench and, whilst I do notice they are on there (2.5kg increase combined)...after a week or two of the new weight, I'm doing the same reps as I did before I put the plates on.
Troy, whatever you're doing, keep doing it, and share some of it around, f**k. It's like you grew a chest in 1.5months.
Coz of the current tone of this thread, I'm not sure if you're being sarcastic or not lol.
I'll assume you're not, so yeah over the last couple of months I've focused much more on incline press than just flat bench. Likely culprit.
Did you not used to have them? I doubt I could progress without them on bench!
I can't bare putting those little f**kers on... I know I should but they just look so silly!
yes, the usefulness of small weights are so underestimated - people always worry about how much weight it looks like they have on their bar (this is so stupid) but screw that, use those small weights to make your improvement each week!
edit: HAHAHA nick i was typing that and as soon as i posted, yours appears before mine: point illustrated.
Edited by darksky34
could if you squatted more....
have looked for those little plates, swear there are only two at the gym i go to
when I first looked at the pics I was thinking pretty good improvement for 12 months... then I saw his post, 6 weeks! WTF dude
They were always there, but pretty much what Nick said. There's some psychological barrier about using them, like you're not making much difference by putting them on or it'll be a pointless increase. Only ever stepped up with 2.5kg or 5kg plates. But when you rationalise it, 1.25kg plates, even every 2 weeks is a good increase. You give it 2 months and that's a potential 10kg on your bench, just takes patience. I doubt that by adding 10kg straight up, you would accommodate the reps after 2 months (unless you're a noob still getting noob gains).
Now I'd use 500gm plates if I had them!
Nick start using them, they are a godsend.
dat der celltech?
Edited by GHOSTrun
I can't say it's exactly 6 weeks. The first picture was taken well before the "cut" and switch to incline press, though I looked almost identical to it when I started the 6 week period regardless. The pictures were more to illustrate fat loss (which the first one doesn't show very well).
More or less, yeah that change was 1.5 months though, give or take from inaccuracy of first picture.
dat der celltech?
NAH BRO IT WAS ALL THE ALBUTEREX.
hahaha
    • I would be looking at the tune mate. How do you know that you have such a low dynamic compression?  I had to dumb mine down because it was too jumpy when taking off (too much torque).  What ECU? Do you need help with the tune?
    • Surely the cam timing is set to something stupid at low RPM?
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
