the PCYC has a court upstairs so I'll go shoot hoops for 15mins to warm up... then squaaaats;)
put a hoop up recently... on the front of the car port... haven't had a hoop since I was living at home many moons ago... daylight savings is awesome, get home from work and have enough daylight to shoot around
having a basketball game the day after a powerlifting comp doesn't work particularly well... feels like your in slow motion... epic lower back pump
Bought myself a close grip handle for T-bar rows since the one my gym has for the seated row is a ghey piece of shit without a recession to sit the bar in between the handles. Turned up yesterday (I think it was overnight delivery lol). f**k I love T-bar rows, back is really feeling it all the way through my traps and lats right now.
One of the many great purchases out there to take to the gym with me. For $35 it's not bad.
I find T bar rows the best back exercise for the mid back... especially with the little v handle... better than barbell rows IMHO
I always use the smaller 10kg plates for this... makes for more loading/unloading but you can get a better ROM as the bigger plates hit you in the chest before you can really get your elbows up and back
you can also use that handle on the pull up bar... lean back a bit and pull your chest up the the handle etc
This post. Spot on. Love it.
I can get a better contraction with my hands in that position... I feel it works the rhomboids better... as long as your not too upright and using lots of body english to swing the weight up (then it becomes a half shrug movement)
I also like Pendlay rows and one arm dumbbell rows... The Pendlay's I like to go heavy and not too strict on form... T bar and dumbbell rows done strictly with a pause at the top
barbell rows into my stomach, navel region... T bar rows into my sternum area
reverse flyes for rear delts... powercleans for traps... pull ups for lats... Deadlifts for all of it
love training back lol
Ok so i'm going to try Rippetoe's starting strength for the first time tonight. I'll be working at it for 6-8 weeks over this summer as I now have down time to sleep and eat a bit better now that my CIT course is finished.
Lets see what sort of strength gains I can make...
Got Milk?
PS - there isn't enough deadlifting in his program...
I know he goes on about it needing more recovery time etc etc.
But I got stuck on a shit weight for a long time doing it his way.
added more volume for deadlifts and shot up many kilos for it.
Edited by TTT
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
