2.5kg every time you do that lift.
if you are squatting 3 times per week, it's 7.5kg increase that week.
Mon = 100, 100, 100
Wed = 102.5, 102.5, 102.5
Fri = 105, 105, 105
Mon = 107.5, 107.5, 107.5
and so on.
If you have smaller plates (I've got a pair of 0.5kg for example), then use those when shit gets hard.
and it will.
hence if you don't do GOMAD with this program, and stall on you rlifts and you ask a question on his forum you'll get YNDTFP (You're Not Doing The f**ken Program)
Cheers for the info. The gym I train at only has 1.25kg plates as the smallest unfortunately, so I'll see how I progress.
Not quite drinking a gallon a day, but easily hitting a litre a day, and that's fine for now until I plateau.
I'll be happy if I hit a 100kg bench, 120 full squat, and 140 dead by the end of summer. Aiming high for me personally.
Mon = 100, 100, 100
Fri = 105, 105, 105
and so on.
and it will.
This is right. You're going to need smaller plates as you will struggle to keep adding 2.5kg each time, deadlift should be able to do 2.5kg each time though.
If you can't get the 3x5 for a particular lift for 3 consecutive workouts you need to reset the weight (from memory 10%) then work your way back up. As a general guide, people say if you stall and reset on the squat 3 times, it's time to move on but too me that is a big generalisation.
If you are stalling then it's a good idea to check diet and if you're getting enough sleep. You should also keep a pretty basic log of lifts etc.
another thing..
There was no info about what weight to start at..
So what I did was, I took about a week and did sets of 5 reps and kept increasing the weight till I could only get 4 reps.
Then went back about 5kg and started the program there.
2.5kg increase for deads and squat will be fine.
Bench and OHP and Power cleans will be a struggle alot sooner than SQ and DL.
damn straight... this is what I'm focusing on now... OHP and cleans... been stuck on similar weight for far too long... mainly because I was doing them as assistance... hoping the OHP helps my bench and the cleans help my deadlift
Maybe just buy yourself a few fractional plates or something to take with you? 0.5kg plates can be had pretty cheap
Are those 1rm lifts or for reps?
Nah, It's all good because I'm not doing this program for as long as some other guys would. Hopefully by the time I wrap it up I'll only just be in struggle town to increase weights.
Those figures are for 5 reps
How's the diet going fatty?
haha shit... I've just upped my carb intake as I was pretty flat
dropped a little over a kilo... if your in the right light, I'm flexing and I haven't had much carbs you can make out my top 4 abs... hardly shredded but starting to take shape... almost ready for teh festivals* lol
* just kidding, like I can be arsed going to festivals anymore
82.5kg is going to be a struggle... I'd have to eat super clean consistently and avoid any hypertrophy work... however all the programs for increased strength while maintaining the same weight are very hard on connective tissue so we'll see how it goes
I was down to 82-83 for a while last year when I was doing a circuit session every week... but then I started the powerlifting and taking a protein supp, it sort of shocked my body into adding muscle... now I'm 86-87kg
I guess I'll work on speed and technique for a while, leave the heavy stuff til January... I'm not going to kill myself or my progress trying to get under 82.5kg
yeah 82.5kg is looking unlikely for me too.
we'll stick to the 90s I think.
I'm about 86-87kg at the moment too.
If I'm in the right light, and in the right angle, and still wet fromt he shower, slightly turned with good posture, you can defintely make out that I'm balding... :D
GPC States is April 6th for QLD.
That will be my next comp.
18 weeks should be plenty of time to get back to in to benching slowly and hopefully better my 2012 Nats effort.
Bench - 80
Full ROM Squat - 85
Dead - 120
All 5 reps, all very average. Never properly trained for strength before.
I'll be interested to see how your lifts progress using the program. My lifts have stalled a bit with my current program and I have been toying with the idea of a strength program for a while to help get the on the move again.
If only Markos had a setup in Canberra!
6ish months 1rms
Squat - 50kg - 115kg
Bench 65kg - 90kg
Deadlift - 100kg - 145kg
Couldn't believe I could only do 50kg squat haha, Ah well got to start somewhere I suppose.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
