Protein, creatine & BCAA's are what its all about :)
Using Max's supersize protein 5kg 3-flavour pack (cookies & cream is SO awesome!!), with milk
Some sort of ebay creatine powder
And my 2kg amino acid mix from Mr.Supps, consisting of:
- 100g D-aspartic acid
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Plus take multi vitamins, iron tabs, ZMA tabs, and a little bit of Toco-8 powder in my post-shake with a tablespoon of the AA mix
Found Double-T Sports Nitromine (360 tabs - pretty much amino acid tablets) for $9 a bottle from Supplements Direct (usually $90! wtf??) so I grabbed a few bottles of that with the Toco-8
snake oils. meh. Ive got no problem taking plenty of amino acids, more is > than none :)
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Man that's a lot of stuff...
Also the glycerol isn't an amino acid just incase you thought it was...
yeah I know :)
bulk buy of the AA's is actually cheap in all honesty, 2+kg was $~90 and it'll last aaaagggggeeees. Mixed in one big tub.
protein and creatine is as it should be.
the tabs? well, ..... taking them "just because I can" :)
- the iron, zma and toco8 is because I reckon my testosterone levels are low due to a number of reasons.
- multi V's 'cause I think its better to take one then not ;)
- Nitromine, well Im a sucker ;) snake oils!!!
* the glycerol is meant to help get the protein/aminos into the muscles? ... "taking glycerol in supplemental form quickly improves hydration and the absorption of other supplements that are taken with it."
If you want a test-booster, grab some dianabol or Trenbolone or Oxandrolone...
Isn't just about any "test-booster" legally purchasable on the Australian market nothing more than snake oil anyway?
- 250g beta alanine
- 250g L-tyrosine
- 250g creatine
- 250g L-carnitine
- 250g L-glutamine
- 250g L-leucine
- 250g glycerol
Geez dude just buy some steak, heaps easier
No; never!! - my 2kg AA mix will last a year, and cost something like $96 all up :)
I dont see the issue - protein, bcaa, creatine, vitamins......
It's entirely the cost when you compare it to something like chicken breast, at least considering you still need to consume food even if you're taking all those supps.
Creatine - Ive had since start of the year
Ammino mix - will last a year (10g per shake makes 200 shakes!), and for the bulk size thats pretty cheap in all honesty
Protein powder - IMO you're crazy NOT to take that shit post-workout, plus the cookies & cream is like a party in my mouth but you're all not on the vip list (sorry!)
Multi V's - Ive always taken them
the rest isnt needed :) granted; snake oils* thought Id try the toco-8 and zma tho as a once-off.
you all jelly at my knees of fury & not needing to squat - that must be it. =p
as for cost, ebay is your friend ;)
hey if you have the money and time to use it, go for it. It might be that 2% that makes a difference.
However unless i was a competing bodybuilder or elite athlete of some sort then i'll spend that 2% elsewhere, usually at jb hifi
So im guessing u dont use sups Simon?
havent seen ya at the gym for ages, been busy obviously
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
