False!!!
sent from bathroom using one hand
So you're saying fapping doesn't have any adverse effects on test levels?
To my know knowledge studies have shown no fappin for a lengthy period of time elevates testosterone levels
" This current study examined the effect of a 3-week period of sexual abstinence on the neuroendocrine response to masturbation-induced orgasm. Hormonal and cardiovascular parameters were examined in ten healthy adult men during sexual arousal and masturbation-induced orgasm. Blood was drawn continuously and cardiovascular parameters were constantly monitored. This procedure was conducted for each participant twice, both before and after a 3-week period of sexual abstinence. Plasma was subsequently analysed for concentrations of adrenaline, noradrenaline, cortisol, prolactin, luteinizing hormone and testosterone concentrations. Orgasm increased blood pressure, heart rate, plasma catecholamines and prolactin. These effects were observed both before and after sexual abstinence. In contrast, although plasma testosterone was unaltered by orgasm, higher testosterone concentrations were observed following the period of abstinence. These data demonstrate that acute abstinence does not change the neuroendocrine response to orgasm but does produce elevated levels of testosterone in males. "
http://www.ncbi.nlm.nih.gov/pubmed/11760788?ordinalpos=16&itool=EntrezSystem2.PEntrez.Pubmed.Pubmed_ResultsPanel.Pubmed_RVDocSum
I don't agree at all.
Regardless of all the physical aspects of it, which i don't know about as i haven't researched it, you have the mental side.
And if doing it makes you feel better, and happier, and less grumpy....then i would say it's good for wellbeing
Fapping is not good for general well being anyway so its better to abstain from it all together
f**king lol.. what are you some sort of religious extremist?
Forget test and forget the fapping... dumping your load more frequently is better for your "health"
Wether you do it by hand/whore/pumpkin/vag/arse/mouth or tit is up to you.
Doesn't mean you should lock yourself up in a room with porn, tissues and cream to try and break some records.
There were guys on bodybuilding.com or whatever and they didn't fap for a month or so to see how it affected there gains, dont think it went to well.
I think it actually decreases your test if you dont 'go' for to long. Lifes to short to not fap for the sake of marginally higher test levels, cant tell me you'll actually notice a difference between a fapping bodybuilder and a non fapper.
lol
it may or may not be better for your own wellbeing... but I can guarantee its better for everyone else around you
food, sleep and sex... if I don't get enough I become a rage monster... Hulk smash!
many fighters abstain before fights... claiming it keeps them focused... I reckon it just makes them angry... which probably works too
When you don't fap/have sex often, the body has less of a need to produce sperm and testosterone, therefore lowering your overall levels.
Frequent ejaculation also decreases the risk of prostate cancer.
Studies have also shown a spike in test levels after sexual activity, and there is an increase in the strength of compound movements (such as squats) while on this test spike.
Jesus Christ man, do you even have a dick?
So it's no longer a question of who juices and doesn't...it's now "he must fap".
They must be talking about like 8 hours after...
Cause straight after is snooze time.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
