165...somebody stop me! Head started spinning as soon as I locked it out :S
Gotta run out of steam soon; at this rate I'm adding 10kg per week.
170kg. Was a fair struggle to get it up and lock it out. I did it straight after the deadlift challenge, so that no doubt made things tougher. Regardless, I'd say I'm pretty close to a 1RM plateau. But nothing 2.5kg increments and increasing the weights on my working sets won't fix :)
Birds, warm up is no doubt important, but there's plenty of research out there to show that static stretching reduces strength/power. So it's probably better to dynamic stretching or just stick with stretching in the movement with progressively heavier weights.
bit too general about claiming static stretches reduce strength. That chestnut is wheeled out all the time.
I static stretch I don't find myself becoming a feeb., quite the opposite. They are needed to help keep alignment in posture and position for lifts in my case. As you get stronger it's good for those like me who use it to get the ROM and alignment in check. Hard training sometimes has me stretching for days in the area effected. I am not trying to have ever increasing ROM , just reach the right amount for position and lift.
He is talking about static stretching right before you are training. When you static stretch, you reduce the blood flow to that area. This is obviously not a good thing right before you are going to load the muscle.
I do lots of static and pnf stretching, but at home, when i have an hour to do it properly. Cause you will be bloody sore if you stretch properly, and you need time to do it.
You don't need your muscle to stretch any more than the rom of the exercise you are doing. So just warm up with the exercise you doing, obviously start light and work up. If you can't do the full rom of the exercise, you need to work on this outside of the gym, as, like i said, you need time and it hurts.
I hear what you are saying rev. But I have 2 comps this year that I am doing. Bench has always been shit anyway.
Best of 110kg in a comp.
That was the reason I did a program where I benched 4 times a week. Max bench stayed the same and I picked up this condition.
After June I'll stop bench for a while.
Meantime I'm going with the physios word.
I'll look up what these Cuban presses are
Cubans and L-Laterals. Then shoulder press once you are strong. This will have your bench going through the roof in time.
Start out with just very light weights and see what you are like on them.
Edited by rev210
Thanks for clarifying what I meant, i probably should have been a little more specific.
ok so the cuban rotation is essentially what I do with one arm and a band so I'll give it a go with a broom stick handle to get it right and see how I go from there.
the L-Laterals I'll try with light light shit first.
Ah well thats a better explanation and I agree. However, I still static stretch before the lifts. To check ROM mostly ,so not as involved as post workout static stretching. The blood flow ,assuming warm up is a non issue. I still have my doubts about information (statistics) that indicate a decline in strength as a result just prior to lifts. There appear to be just as many recent studies debunking this idea.
Farrrrk Kai Greene has some size, I think he's got
It In him to take Phil this year (I thought he did last year though)
In other news, did another 5x5 session today .
Got my bench up to 91kg, power cleans to 82.5, chins to 25kg and deads to 127.5kgs. Small improvements, but still improvement I guess!
Edited by Mitcho_7
Locked out 170kg deadlift this evening, actually much easier than my last failed attempt. f**king stoked!
Nice work! Now I have to pull 175 to stay ahead of you...
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
