I would never like to use supplements or any other shortcut methods to strengthen my body and shapes. As it could lead to some real damage to our body later in the age, as it start losing skin too early and by using supplements we might end up on wheel chairs at later parts of our lives.
There's no supplement to fix what you have.
I never actually thought my dips were THAT low haha...now you've got me thinking I am going too deep :unsure:
If its not causing you any problems thus far, stick with the way you are doing it.
On a personal note, I can't get much below parallel without it stretching the crap out of the front of my shoulder.
Snakebrah?
Just watched that dip vid, great depth.
God I can't wait to get a rack with a dip station.
I'm still looking for some feedback on the recent vids on my build thread if anyone would care to comment.
Changed some things, no towel on the bench, SLDL instead of DL, and using full weiht on things for demo purposes.
http://www.skylinesaustralia.com/forums/topic/421637-project-squat-dodgerno-more-curling-like-a-broget-ankle-better/page-4
That link for the rack you showed before may not be optimal for dipping for you, who's to say the grip width of the handles won't be too wide for you? The ones on mine are angled so you can place your hands on different parts of it to get the proper dipping width.
Also, if I have a bit of tightness/discomfort/ a twinge in the Thoracumbular Fascia area that seems to be aggravated by exercising, is lower back stuff more likely form or too much weight related?
http://vanessaruns.files.wordpress.com/2010/03/back-muscles.jpg
I'm having my lower back/pelvis worked on as part of physio for my busted ankle, which saw me walking unevenly causing pelvis rotation, and am doing light back/shoulder stuff as part of my gym work, but it doesn't seem to want to go away unless I stop all gym work.
I have some specific oblique and inner glute exercises that I've just started doing on the advise of a Myo and a Physio.
I've got form videos in my build thread but the comments tend to be that form is "ok" and that the weight is light and I'm a girl :D Bare in mind that until recently I was squat dodging and doing little to no back/shoulder work.
Anyone else had experience with injuries in that area?
Edited by ActionDan
oh there is a name for that spot.
that is where my pains are.
I try to get tight everywhere around there before lifting.
but clenched, lower back arched, shoulders back and down, lats engaged, big breath in, crush the bar and up it goes.
so I'd say it is a combo of form and weight.
gotta learn to stay tight.
Just watching your vids with squats and deads, and I realise that you are doing light weight to show form, but you don't set up at all.
you get in to position and lift.
As an example of setting up, look for a video of David Tate talking about Bench pressing.
even with an empty bar, it takes him a good minute to setup his position etc.
Your back will hurt less if you setup right and get tight everywhere, then lift.
Think of which body parts are doing most of the work and certain points in the lift.
deadlift starts off with leg drive and then changes to hip pushing through and shoulders locking back.
etc etc.
etc etc.
In the second set of videos, the ones that didn't embed, that was actually at training weight, yes only 50kg. I've squatted and SLDL more in the past, up to about 80kg, but have never had this sort of back discomfort. The real pain, especially squat, is getting the weight up and over on to the shoulders which is why I will buy a rack.
I'll try and pay more attention to tightening up things before going through the motions on Wednesday. The weird thing is, I do not feel notable discomfort during the motions, only the next day - aside from the shoulder twinge I had but that seems to be OK now.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
