I've simply given up on deadlifts indefinitely. I'm not a power lifter, I give no f**ks for them if it's just going to consistently end in crippling pain. Sure, it's more than likely just incorrect form - but what it breaks down to is it being easier to just not do them any more lol.
I find SLDL easier on my back personally, I assume that lanky legs makes the set up and lift off portion harder to do safely/easier to stuff up, perhaps wide stance is a better choice?
I will stick with SLDL as I just find it that bit safer for me and my obvious back weakness/poor form.
I used to think this way, was happily doing sets of 10x120kg on stiff leggeds...thought it was decent and was happy because regular deadlift form seemed retarded to me; I just couldn't do it; couldn't get the bar past my knees easily etc. Then one day I reset my form to try off the ground...starting with like 70kg. You get use to it quickly. Have since far surpassed what I was doing on stiff leggeds. Such a better exercise! I never ended up dizzy after stiffs; after off the ground I want to faint...
Yeah I've given up on Bench in that sense.
Haven't benched in like 2 months until yesterday when I went in to test openers for this weekends comp.
I managed 100kg which was ok'ish speed.. enough to open on.
My previous best in comp was 110kg,,
lol.
Yeah shoulder and elbows.
My point is, I have/had a weak bench. so I benched more. this hurt my shoulder/scap.. So I started doing more chins and rows and scap stuff to strengthen the opposite side of chest, this gave me elbow issues (tennis and golfers elbow)... so I gave up on it.
Didn't bench, row or chin for 2 months.
I'm 6kg less than when I benched 110 and then benched 100. Will probably get 105 on the weekend.
All I really care about right now is to get my squat up as it is the one lift giving me the least grief.
States this weekend then Nationals in June. If I don't get any NEW pains I'll be happy.
Edited by TTT
Fair enough, I think you have different goals than me, and likely others, so us avoiding a lift is less detrimental than it might be for you.
Especially in my case where it's purely for a combination of not looking like a 60kg IT desk jockey and general health and well being.
My goal was to lose fat, strengthen my legs after I got them operating correctly, mobilise my body from shift work numbing it to a point where I couldn't be bothered doing anything and to do it in as little time as possible.
Within a month i realised I'm not a fan of spending hours in a gym.
Edited by jangles
Efficiency at becoming the strongest I can in the most efficient ways, whilst achieving fat loss and muscle gain.
I didn't switch to these after a month, I just realised how so many people around me are forever in the gym not seeming to change, shape, size, strength
Edited by jangles
you wonder why they keep coming back... I guess it does help you feel good after a day at work... but for the time, money and energy spent I want more than just a bit of a buzz
What's to say they aren't just maintaining general fitness or recovering from an injury and doing physio, let alone doing it purely for enjoyment.
Being in the gym for any reason is better than someone putting strain on the public health care system due to poor health when it can be helped.
Easy for me to say though when these people aren't getting in my way.
Edited by ActionDan
My point exactly nick. Going through the same old motions, doing same old weights.
I wouldn't spend money on upgrades for my car for it to be the same as it was.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
