Bench was going great tonight; best weights I've pressed in weeks and all nice and low to the chest. Last set was 2 reps of 107.5kg. No shoulder pains. Then did close grip lat pulldown. Still all good. Then warm up on 60kg incline press and...f**k...my shoulder cracked the shits. Felt like I dislocated it or something. Couldn't even finish the set. Now can't move arm in certain ways (specifically above my neck and across my body) without it hurting.
Gonna book for scans tomorrow; looks like I'm deadlifting and squatting indefinitely.
That sucks.
Is it a pinching type of pain? Does it 'pop' when you move it high or across?
Yes it's pinching and if I can stand the pain of moving my arm high it does pop eventually. Can't even take my farkin T shirts off, it's ridiculous. Still can't believe a 60kg incline press did this...
Doc pressed on a few places and seems to think inflammation of the supraspinatus/bursa; prescribed anti-inflams. I reckon it's a tear/rupture though, so I insisted on an ultrasound referral. See what the imaging reveals I guess.
FML
FML
Sucks :(
Hopefully ultrasound will give you more information and you can get it sorted.
but your life isn't that bad
FML
should of insisted on an MRI referral.
Ultra sound will only show youve got an injury/fluid.
MRI will actually show length, extent of injury etc.
MRI will also set him back a shitload of money. Prior to healthcare reimbursements (which won't be much anyway), the MRI my mate got on his knee not too long ago here in ACT cost somewhere just over $500.
$500 is not a shitload of money when it comes to your health.
Most people wouldn't think twice about spending $500 on their car.....your body is with you for the rest of your life
Oh I'm not saying it isn't worth it; merely saying that perhaps jumping straight to an MRI isn't necessarily the way to do it. I'd go with the ultrasound first up as it's probably close enough to free for there to be no real reason NOT to bother, and then depending on the results of the ultrasound you could push for the MRI.
FML
With the shoulder it could be anything but it sounds similar to my injury which is bicep tendinitis - basically the tendon that runs from the bicep to the shoulder is enflamed and pinches and pops as it passes through the hole(?) causing the pain.
Physio, Voltaren, stretching and no chest work for 4-6 weeks cured it for me but then it came back again. And no overhead presses of any sort!
Good luck with whatever it is :)
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
