Might look to MRI if the ultrasound doesn't tell us much. The ultrasound should be free through Medicare. Think I'll end up like you John...likely ill be able to do bench press again but no overhead movements for a long long time. Might get onto some rev shoulder care exercises when I get movement back.
Anti inflams are helping a bit with the pain. I love and hate my GP; he doesn't seem to like consultations going for longer than 30 seconds, but he always knows how to fix ailments and will prescribe anything you want him to.
Trollga if I could lift my arm I'd sock you in your twisted spine, brother.
$500 is not a shitload of money when it comes to your health.
Most people wouldn't think twice about spending $500 on their car.....your body is with you for the rest of your life
I agree with you. I guess for the same reason, people don't get regular check ups and screenings for terminal illnesses - likely they don't feel they're getting tangible return on investment like you get with a car part or the cure of existing ailments. They wanna feel a difference has been made lol
I'm all for yearly blood tests and scans.
Suppose it doesn't help that the worst medical experience of my life (and likely the worst I'll ever have short of death) involved vomiting all over myself while getting an MRI....doesn't really give them a good wrap in my book :P
Haha!
Exactly. I've spent more money on my health in the last couple years than most spend buying/modifying cars.
No exception when it comes to health. Gotta have this body for another 40-50yrs at least I hope.
On a serious note, injuries always make you feel like it's the end of the world/why do I f**king bother etc when they are new.
in a couple of days time, with NSAIDs the pain will dull and it will be some what better.
you'll start over and it'll be fine.
Cheer up lightweight
Bench was going great tonight; best weights I've pressed in weeks and all nice and low to the chest. Last set was 2 reps of 107.5kg. No shoulder pains. Then did close grip lat pulldown. Still all good. Then warm up on 60kg incline press and...f**k...my shoulder cracked the shits. Felt like I dislocated it or something. Couldn't even finish the set. Now can't move arm in certain ways (specifically above my neck and across my body) without it hurting.
The damage occured on that first bench press. It takes some time for the inflamation to build on rotator injuries.
Don't worry you will recover. Ice the rotator area regularly and anti-inflamitory pills and arnica cream.
When you are fixed up , get the shoulders tough and you won't look back. At least you can do bro-press with less risk.
For anyone using foam rollers/balls etc.
I'm specifically interested in it for my lower back discomfort/tension is a foam roller or a ball going to be a better option?
There's a bit around to say that foam rolling the lower back is a little risky if you're not supporting yourself properly etc.
Hmm, I have suitable balls at home that should do the job, just not sure if I need the roller.
Given I'm trying to target the Thoracumbular Fascia area specifically. Can't see how a roller would get in there. Pic for ref again.
http://vanessaruns.files.wordpress.com/2010/03/back-muscles.jpg
Also, on my Myo's advice I'm seeing a Podiatrist (well a 3rd year friend of mine) to have a gait analysis done and have the rom of the ankle/foot, leg lengths etc examined as my ankle is definitely different to the other one now and the MYo is convinced my back is a compensatory issue.
Edited by ActionDan
For that area I've had good results even with a tennis ball, just moving around until I find the spot then lying there with as much pressure on it as I can bare the pain haha. Works well. Would be intense with a PROPER ball for rolling that doesn't just squish lol
Anyone here joined Fitocracy (on the web or through the app)?
Great little fitness 'social networking' thing I joined a few months ago.
https://www.fitocracy.com/
Plenty of fit girls on there also... (and guys, for the girls on here).
    • A realistic expectattion of how long it has to last also comes down to.... when do you think you will be banned from registering and driving old petrol powered shitters? It's 27 years since that thing was built. It probably rusted out 15 years ago. It was probably repaired and looked OK for another 10. If you do a similarish bodge job now, or perhaps slightly better with some actual rust conversion and glassing, then.... get another 10-15 years out of it, after which you'll only be permitted by the CCP to drive electric cars manufactured in their Shenzen zone anyway.
    • Let me assume that the concern over a manual ECU is that the NeoDET that you have was an auto and has an auto ECU. That ECU will not be a problem, but you WILL have to Nistune it. And you would have to Nistune it even if you had a manual ECU, because the turbo ECUs will shit the bed if they do not have all the things that they were told they have to have, to be happy. The big one being the TCS CU, which you won't have in your car. Anyway, with an auto ECU (which I have running my originally auto NeoDET in an R32) Nistune allows you to put in a Stagea image which doesn't panic about the absent TCS, and allows you to override a whle bunch of other annoyances that would otherwise see the check engine light on 100% of the time. Also, you can't wind up the power very far on the stock NeoDET ECUs without Nistune, because the boost sensor gets in the way. Nistune allows you to push that problem much further up the dial. Do you even have the boost sensor with the engine? Without it, you are SOL and will need an aftermarket ECU (or to find a sensor somewhere, god knows where). I can't tell you what the wiring loom differences are in a 34. But what Duncan said above needs to be considered. When you say "loom", does that include the transmission loom? Because you will need to swap out the auto tranny loom for the equivalent manual loom, and get rid of the neutral/park start interlock (basically hot wire it).
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
