Has anyone had experience with the Hex Trap bar?
Looks like it could be a bit easier/safer on the back.
I'm not about to buy one, just a random discussion topic more than anything.
Part of me thinks that it'd allow you to lift more without risking the back, but at the same time makes me think that if the back is supposed to be getting a workout during DLs then you're kind of cheating.
I'm thinking it makes the squat a pull exercise rather than push too.
http://www.t-nation.com/free_online_article/most.../the_trap_bar_deadlift
Edited by ActionDan
Looks like it just targets your legs and traps more due to being able to load more weight onto the bar and retain a more upright/vertical spine.
You're right, somewhat defeating the purpose....though I'd definitely give it a shot myself right now - surely better than not doing deadlifts at all :P
Yes you will, I'm pretty sure your post count will start going backwards now too.
Until you go and squat again.
And don't hate on vagina's a decent one can take an absolute pounding.
Edited by ActionDan
I didn't squat last night when I was supposed to, will I lose all my gains?
If you don't mind contracting superaids and head cancer, you have nothing to worry about.
People keep referring to vaginas in a derogatory sense, implying weakness.
It's been said before, that testicles are pretty damn fragile, but the vagina can take a pounding by comparison.
Take that how you will :D
Edited by ActionDan
It's been said before, that testicles are pretty damn fragile, but we vagina can take a pounding by comparison.
Vaginas ftw.
Exactly. Doing this exercise to avoid an injury that never used to be there is defeating the purpose of building the back stronger.
Stronger back = deadlift more.
Working the rest of the muscle around the problem makes those muscles stronger, but not the injured ones = imbalances
Imbalances are right up my alley, I should definitely get one.
Just gettig freight quotes on racks at the moment.
What?
I'm saying deadlift the proper way after, in this case back, is healed.. Not do something that is a way around fixing the issue.
thoughts about tough mudder?
http://toughmudder.com.au/
was thinking about doing some training for it in september so bit of time to get 'fit'
Hit the uphill cardio with a weighted backpack and run through water.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
