$10 per kg pretty much. Though as you can see diff protein contents - my point being, realistically if I'm going to see any difference from the lower protein amount given my workload. I'm guessing not.
Ayo if you don't care about mixability and lactose, go the concentrate. Personally I can't stand unmixed shit, so I like the isolate. I also have a slight aversion to too much lactose.
Okay, well that will certainly mix easier than the concentrate...but meh...get a sample or a 1kg bag of the concentrate and see what it's like?
I go through this stuff fairly quickly, so even a 5kg bag of a bad flavour or something doesn't phase me.
I find concentrate mixes fine, have had a few brands no clumps. Just don't be lazy and only shake it 3 times.
Edited by Mangune
Either way (including calcium cassinate), easiest way to mix is with a stick blender in a tall cup , I do oats plus frozen blue berries as my breakfast with some non flavoured pure protien. Simple clean up and ready in seconds.
Concentrate is slightly slower to digest vs isolate (both are rapidly absorbed however , so work as post workout pretty well). If you don't care about taste ,Concentrate is the way to go.
ive gone off pretty much all supplements. Only the occasional pre workout if i am real run down after work.
otherwise its just food food food for me. Getting pretty tired of eating chicken, fish and steak though...
    • Wanted to clean the film behind the triple gauge so the lights show through better.  Progress so far….
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
