$10 per kg pretty much. Though as you can see diff protein contents - my point being, realistically if I'm going to see any difference from the lower protein amount given my workload. I'm guessing not.
Ayo if you don't care about mixability and lactose, go the concentrate. Personally I can't stand unmixed shit, so I like the isolate. I also have a slight aversion to too much lactose.
Okay, well that will certainly mix easier than the concentrate...but meh...get a sample or a 1kg bag of the concentrate and see what it's like?
I go through this stuff fairly quickly, so even a 5kg bag of a bad flavour or something doesn't phase me.
I find concentrate mixes fine, have had a few brands no clumps. Just don't be lazy and only shake it 3 times.
Edited by Mangune
Either way (including calcium cassinate), easiest way to mix is with a stick blender in a tall cup , I do oats plus frozen blue berries as my breakfast with some non flavoured pure protien. Simple clean up and ready in seconds.
Concentrate is slightly slower to digest vs isolate (both are rapidly absorbed however , so work as post workout pretty well). If you don't care about taste ,Concentrate is the way to go.
ive gone off pretty much all supplements. Only the occasional pre workout if i am real run down after work.
otherwise its just food food food for me. Getting pretty tired of eating chicken, fish and steak though...
    • you can enter your VIN (the original, japanese one) here to find the correct part#: https://www.amayama.com/en/genuine-catalogs/nissan however, after all this time it is more likely to be a wiring issue than the sender
    • no, it was the same here, just flurries but no need to get the toboggan out....but it is exactly the sort of days where its good to have some inside jobs on the list. Speaking of which the fuga is driving properly after 2 1/2 years.....but that is a whole other thread
    • And yes, put in the restrictor while you are there; a standard engine is fine with a little less oil and you are less likely to run out of oil if you have sustained high revs for any reason eg visit a track one day. How did you clean the cooling system
    • I didn't think about how a circle works before, dumb.  Before, I had .9mm restrictor bolts but I can't use these cause they were shorter aluminium bolts that just tear off their threads when tightening since the OEM lines are thicker than the shitty braided one that was installed previously. Now I use longer 1mm stainless steel restrictor bolts. I think the difference will not affect the health of the turbos, but I guess I'll have to drill out the main feed bolt as I agree multiple restrictions sound dodgy. The one that was installed with the braided line was just too short, but completely without a restrictive hole.
