Yeah I don't think DLs will help muscle tension lol but cheers.
Abs split during pregnancy then heal up after, that's par for the course, she's not too far off being healed up. In the meantime is just walking/jogging and doing light exercise to stay in shape.
The weird thing, when she does something like push ups her shoulder muscles get really tense and it'll give her a headache. Likewise if she runs her legs get mega tight.
I'm not quite sure what chemical reaction in the body causes muscle tightness but wondered if it was something that could be fixed by having more or less of something in the diet. As in, lots of people use glucosamine or fish oil for joint discomfort, is there a similar supplement/vitamin that could help alleviate muscle tension... besides some kind of sedative lol
EDIT: This has a few things in it for ideas.
http://www.flannerys.com.au/ask-a-naturopath/question/119
Edited by ActionDan
Have you/she tried deep tissue massage?
not "honey let me rub your shoulders"
more "ok try not to cry while I torture the muscles around your neck"
She might also have a habbit of shrugging her shoulders up causing the nerves around the neck to get pinched or just tighten when she does exercise..
as in she might not be able to control what muscle she tightens and have a habbit of just getting tight everywhere.
Suggest starting with a tennis ball or harder against her neck and upper back..
she can do it her self on the floor or against a wall and control where and how hard she wants it.
I know she's seen a few physios before and they all comment on how tight her back is, she also has a tilted pelvis.
I've given her a few rubs and I get told not to go too hard and I wouldn't consider myself strong nor her weak in the pain management department but obviously in the shoulders she gets quite tender.
I know she's tried the ball on her butt cheeks before to get in there for some pain she had and she's had a go on my foam roller but it can't really target the shoulders that well.
I might buy her some new firmer tennis balls or a softball or something and see if that helps.
Tennis ball placed around the shoulder blades up against a wall where she can use her legs to go higher or lower or left or right or harder softer..
it works great.
find a sore spot and and just lean on it harder and harder.
If all that fails, find a physio that does dry needling for instant pain free release.
I've had success with dry needling.
I see the ball/massage as being a bit of a treatment, but I was after some ideas on prevention/cure so to speak.
It's good to be able to get a massage or tennis ball in there, but it'd be even better to eliminate/treat the root cause.
it's not going to be something magical mate..
it will either be her posture or a habbit where she tenses things too much.
Maybe she sits with shoulders slightly shrugged or rolled forward and any additional activity by way of exercise causes the tightness to be extreme.
Start with posture.. it's free to adjust.
morning and night tennis ball lovin...
Haha that I know, was just wondering if there were others who had a similar issue and found that X supplement/vitamin/mineral helped a lot.
Fish oil helped my elbow quite a lot for example.
Edited by ActionDan
Dan,
I get shoulder and neck pain from exercise or when I'm very cold, caused from a car accident 10 years ago. This pain also induces migraines. I get migraines on a nightly basis every 8 weeks or so; when this starts to happen I receive trigger point therapy and deep tissue massage. This helps enormously. I can’t speak highly enough of trigger point. My shoulder pain also makes me susceptible to injury in this area, for example my levator scapulae injury I sustained a few weeks ago from increasing my weights; when this happens I book in for trigger point again and it normally heals the injury within a few days. I also consume magnesium daily which assists with joint/muscular pain.
fish and krill oils did nothing for me.
I went from 5 fish oil caps all the way up to 20 per day for months.
I then went for 2 tablespoons of actual fish oil.. look that up to see what that adds up to.
no joint benefit.
Just shiny forehead. lol
same for me. have also read numerous articles that back up that statement.
but my old man swears by fish oil for his knee pain.
might be a placebo who knows
yep I was feeling knee soreness the next day after squatting until I had dat dere fish oil. Same with elbows after arm / chest workouts.
more deep squats would have fixed you knee and elbow pain.....
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
