My advantage of being a diabetic is that I can actually figure out how many grams of carbs I'm ingesting. For eg. my body utilises 1 unit of insulin = 7.5g of carbs. When I have 1 full cup of oats with water I use 4 units of insulin to bring my blood glucose levels bang in the middle optimum range. When I ate a large pizza, I had to use 12 units of insulin which = 90g of carbs (basically the bread). Now 4 slices of burgen bread = 4 units (30g carbs) which equates to 1 cup of oats. Who needs to calorie count when I can calculate it dead on based on my body :)
As a laugh, I had a tiny slice of cheese cake and needed 6 units of insulin (45g). Crazy empty calories from that, not to mention the fats lol
As for fats, I loaded up on peanut butter & brazil nuts and minimised cheese, and red meats (was eating it 4 times a day at one stage) since my LDL cholesterol was at 3.8mmol/L and HDL at 2.7 mmol/L.
Leesh, anyone that wants.
Powerlifting men dont do them, unless Max is punishing one, the girls love them, but only Nina from the competing girls does them
Remember most of my clients just train to get strong and fit
A fireman that trains here goes very well on them.
Farkin firemen...some of those guys are seriously fit.
At my dad's old gym (Markos, you may or may not remember Findlays in Hawthorn/Camberwell), that I used to muck around at when I was a kid, there were some properly strong guys there. One was a fireman who did nothing but squat, all day everyday. He was about 6'5 and a judo champion of some sort. In short, you couldn't have paid me to pick a fight with him. Had a fantastic figure!
Kind of miss that gym...it had 30 year old homemade ball dumbells and old school machines with chains. Only two treadmills and no one used them lol
Findlays was THE gym back in the day. Most aspired to go train there.
My fireman, lets call him David, squats 180, benches 140 and deadlifts 220, around 96kg, very fit. Technique on the lifts is gym quality, bum up on bench etc
He has nearly completed DEATH WISH II
Thrusters - 20kg x 15
Cannonballs - 32kg x 15
UDL- 64kg x 15
C&P - 16kg x 15
Swings - 24kg x 15
2 circuits non stop, thats 150 reps
I encourage everyone to do one. The most common excuse is "I'm going to wait till I get stronger"
Heres a clue, no ones going to stop getting stronger to wait for you lol. History has shown me the guys that get in earliest progress much quicker. Thats how Liam, my 15yo now, deadlifted 200kg at 14 as well as squatting 170kg, at 82kg.
Conor is the same, started at 14, did a novice comp very early, now at 17 and 88kg, squats 240, benches 125 and deadlifts 245
Its not a spectator sport, no one got stronger watching
Since doing a Novice comp in 2011, this is how Conors progress has gone
3/12 - Vic States - [email protected] class
6/12 - Nationals - [email protected] class
9/12 - Worlds - [email protected] class
3/13 - Vic States - 570kg@90kg class
6/13 - Nationals - 605kg@90kg class
He squatted 130kg at his first comp, and 2 years later squatted 240kg, by the time he was 17
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
