Also Dan...do a pinch test with your stomach skin/fat...it's the cheapest and easiest way to see if you're gaining or losing fat. It's not accurate, but it's better than looking in the mirror and it doesn't need to be accurate. Good biofeedback.
This is basically how I control how much junk food I can afford to eat or need to cut back on to sit around my happy 10%
Im going to say there isn't too much muscle mass gained there. but thats only my opinion
Interesting, I'd always thought that squatters got bums. What are you basing this off? Just personal experience? A study?
Glutes, hamstrings and quads. They make your butt bigger.
This is what I thought, but maybe I just want that to be the case because I'm now J-Lo...
Why can't you be more like Troy and send money without all these legitimate questions.
I'll be sending a sample of BN chocolate as it's one of the most commonly purchased proteins/flavours on here and it's the only one I've got. I based the cost on only sending in one sample. I assume $50 or whatever it costs will only cover one sample.
If it doesn't go ahead or there are any indiscrepancies, I'll just refund your monies through PayPal.
OK I'm on board.
I hear people talk about this but what's the best way to go about it?
If the chocolate tests positively, then no real reason to do any other flavour. Good enough indicator that they're legit.
Agreed, I'm using the WPC but if they are right about the WPI then I'll assume they are legit.
I'm gonna assume it's his mum's, lol.
Also again I don't see the point in testing multiple products. Test 1 (choc WPI) - if it's pretty well spot on what the label claims for protein content, then we should be confident all their products will also meet their label claims.
This is amusing for 2 reasons.
1) The subject and message content was not mum appropriate.
2) 16yr old using mums account... lol
He's not legally allowed to have his own paypal account.
(I realise a 16yr old totally can have one, shaddup :P)
OK I'm on board.
I was basing it off the fact that even if your muscles have grown, the reason you are larger is because the fat hasn't disppeared. unless youve grown ridiculous amounts of muscle.
At 10% bodyfat women start to get problems, their periods stop etc, or become very infrequent. They start to look manly in the face. Most mistake that for being on gear.
I'm talking about a true 10% on a dexa scan, not a broscience one
11 in women in about a 5 in men I think?
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
