LoL yes they do, lucky I have great pins too ;)
Is that a no from you though or just talking smack?
If genuine no, have you tried them? Reviews seem to be pretty positive, in general not brand specific.
Compression improves blood flow. Blood flow is good.
I wear them often, in full tights. Feel it keeps warmth in too.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
Best supplement ever?
http://www.ergo-log.com/9-kg-more-lean-body-mass-with-hmb-atp-combo.html
Subjects put on 7.5kg lean mass taking HMB free acid (not normal HMB) in only 12 weeks. Im not into supps really anymore, more peptides and AAS, but this really caught my eye because those results r incredible, if not more effective than Tren or Dianabol. (roids)
Best thing is, its non hormonal so u don't require post cycle therapy. However its is a sponsored study by the manufacturer which is why i'm dubious, but its worth trying since its legal.
Edited by discoPumpkin
I've got a pair of 2XU compression tights and I fkn love em! They often trick me into pushing further on leg exercises as for me at least they noticeably reduce lactic build up and other such uncomfortable side effects of pushing them reps out :P
Plus they go great under my bike pants lol
ive got compression shorts, not the full length things, only wear them for oztag and would not run without them.
also my old mma pants that held my cup were compression, fantastic
once you get over how gay you look in them, they are sensational.
I haven't tried it so it isnt real............
OK I might grab some socks then and see if it helps.
Has anyone tried Under Armour gym shirts or any other specific gym shirts? At the moment I just use generic nike/everlast old cotton T's
The moisture wicking and odor fighting factors is what appeals most.
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
    • And....if that could be true for all R34 GTTs, then it might be good. But in reality it is not really any better than my standard instruction to "go out and have a look at it yourself, and wave a tape measure around" etc etc, because as soon as you have any adjustable arms, or coilovers with smaller diameter springs, or tyres that have any bulge that goes out further than the rim, etc etc, then the simple version of the information is still potentially misleading. Plus, nothing in this is static. Everything is moving. At the rear the wheels swing inward at the top as they go up, so the clearances on the inside change as the suspension is compressed. At the front it's even worse. And then you have the difference in absolute wheel position in the arch can move around more, or less, depending on how compliant the bushes are. If, like me, you have sphericals on the front caster rods (and on the FUCAs also, but these are probably less dominant when it comes to wheel position), then your wheel will swing forward/backward under loads, as well as up/down, as well as steering angle. You end up having the simple numbers with 17 caveats/footnotes for each.
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
