LoL yes they do, lucky I have great pins too ;)
Is that a no from you though or just talking smack?
If genuine no, have you tried them? Reviews seem to be pretty positive, in general not brand specific.
Compression improves blood flow. Blood flow is good.
I wear them often, in full tights. Feel it keeps warmth in too.
Hmm, do you wear them in the gym or running (or both).
I'm in two minds about wanting to help support my ankle while I run, squat and DL, and not wanting to offer it too much assistance.
The physio said I may need to come to terms with the fact that it will never be 100% and I'll always be making some form of compensation for it and that using things like socks or self massage etc may need to become part of my "routine" to manage it.
Best supplement ever?
http://www.ergo-log.com/9-kg-more-lean-body-mass-with-hmb-atp-combo.html
Subjects put on 7.5kg lean mass taking HMB free acid (not normal HMB) in only 12 weeks. Im not into supps really anymore, more peptides and AAS, but this really caught my eye because those results r incredible, if not more effective than Tren or Dianabol. (roids)
Best thing is, its non hormonal so u don't require post cycle therapy. However its is a sponsored study by the manufacturer which is why i'm dubious, but its worth trying since its legal.
Edited by discoPumpkin
I've got a pair of 2XU compression tights and I fkn love em! They often trick me into pushing further on leg exercises as for me at least they noticeably reduce lactic build up and other such uncomfortable side effects of pushing them reps out :P
Plus they go great under my bike pants lol
ive got compression shorts, not the full length things, only wear them for oztag and would not run without them.
also my old mma pants that held my cup were compression, fantastic
once you get over how gay you look in them, they are sensational.
I haven't tried it so it isnt real............
OK I might grab some socks then and see if it helps.
Has anyone tried Under Armour gym shirts or any other specific gym shirts? At the moment I just use generic nike/everlast old cotton T's
The moisture wicking and odor fighting factors is what appeals most.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
