how does everyone keep track of their workouts?
I use the Jefit app on my phone, keeps track of all my logs and lifts, can add notes if I feel the need and has made it easy to keep track of my workout volume.
Simple notepad file on tablet.
I run endomondo also to keep track of time spent and rest periods and check email, facebook during breaks and sometimes youtube clips on form.
I'm at home though so using a tablet to play my music and record notes doesn't seem as nerdy when you are flying solo.
Deadlift 220kg Birds. In your next deadlift session.. Do it once at least & receive a virtual high five.
You will do it ha ha...
No seriously lift 220.... I am confident you can do it.
Hahaha. Right now I'm confident I could get 200 up; I don't want to try it though, cause my form will be terrible. I'm currently fixing my form with more volume at lower weights for now, as my lower back was getting a bit sore with my "yanking" as Markos calls it.
Also want my squats to catch up, because they are far behind my deads at the moment. But soon I'll return to the deadlift 1RMs and I'll definitely give 220 a crack! Tough ask for a tall skinny 80kg not going to PTC :P
I used to have just a generic diary and would scribble shit down in there, but now I just use a very basic notepad app on my phone. Only really need like 2 weeks of notes at any time to skim back through anyway.
Lunges are the worst torture known to man. I'm properly struggling to stand...squats never did this to me!
They just have this ability to extend the set beyond physical pain and it becomes all about how much you can put up with mentally.
Yea walking lunges say.....for a about 20-30 meters with lots of weight on a barbell on your back is the worst kind of pain especially after the half way mark where you just want to give up because of the intense burn. Not to mention the nice cardio workout that comes with it. I do them twice a week and have developed excellent shape as a result. Squats had sliced my lower back in two so utter fail for me :(
Eating peanut butter
This. lol. And incline leg press (plate loaded). Got up to 360kg for my working sets, so at least I wasn't being a bitch on the thing.
Looks like my ROM issue through my shoulders wasn't quite as bad as I thought, since it was pointed out I had the bar way too low anyway haha...so now that I'm resting it in a more appropriate position as well as stretching my chest/shoulders/etc beforehand, I can do barbell squats again.....my traps are f**king obliterated though, not used to having weight resting on them >.< will get used to that though.
Best part is 100kg feels like nothing! (inb4 that asshat Markos pointing out 100kg IS nothing :P). Should be back up to a more appropriate weight in no time. Will increase 5-10kg for the next couple of sessions, then 2.5kg every session without fail from then on.
Markos, I remember you saying not long ago that nothing you see amazes you anymore. I'm curious: what's the most impressive or amazing thing you've ever seen with regard to lifting?
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
