lol, I was going to insert a video here of Vicki squatting 110kg tonight, but I'm a little scared bozo might put his back out throwing the computer across the room
it might help get my numbers up :D
I noticed my gym has removed some of the free weights area to make room for "true grit" classes, I suppose at least they are using barbells and doing compounds... really wish they would get a second power cage / squat rack though.
Edited by bozodos
Markos, I remember you saying not long ago that nothing you see amazes you anymore. I'm curious: what's the most impressive or amazing thing you've ever seen with regard to lifting?
Great question, but I was amazed last night.
Firstly, the hardest set I've ever witnessed was actually performed by an SAU forum member, Nick Rankin. He squatted 160kg x 20, no wraps no belt. He could easily have quit at 5, it was that hard. He hit every upright in the power rack, he was stumbling, I thought he would pass out, but he never quit.
Most impressive lift I saw in the gym was Max at 16 weighing 70kg, take out 125kg on his back like a squat, then jerk it overhead, behind his neck, stunned everyone. But next, he didnt dump the bar on the ground like most, he lowered it to his shoulders and re racked it, no belt, nothing. This was before he switched to powerlifting
Last night a guy from a Crossfit gym near town trained at PTC, he was there for over 3 hours, he foam rolled everything, including forearms, used bands to stretch every square inch of his body, it was amazing. The lifting he did was overhead squats with 25kg x 3 and push press from the rack with 25kg x 3. I've never seen anyone do less for longer
Crossfit dude might have been working on rehab/recovery? Weird otherwise.
Regarding the more's....
If I can get 8 reps out on sets 1 and 2 but say only 4-5 on set 3 (each set heavier than the one before it) and I see this trend for a good few sessions, am I "better" off (I know that's a loose term) doing more reps of the final set weight? The second set weight? A higher weight? etc.
At the moment, if I fail out at 4-5 on the final set I take a short break, then grab a few more reps at that weight, until I've done 8 total at that weight. Good approach to mores or would more weight be better?
I ask because for 3 sessions I've done the more sets at the same weight thing, to make sure I get 8 at that weight, but I'm not seeing a correspodning improvement in how many I can get out in one go on that final set, still topping out at 4-5, and I'm not racking it assuming failure on the 5th or 6th rep, I'm going for it and trying, getting half way or so, not making it, putting it on the safeties, crawling out, re-racking, going again.
I know effort is key, so im going to failure, when I take a 60sec break and can get out a few more reps, how should I go about them? Same weight, more, less etc.
The problem I see with what your doing is tracking progress.
If your getting 8 on lighter sets then 5 on the only work set youre doing, thats not much work, is it?
I'd rather see bench - 80kg x 5,5,5 than bench 60kg x 8, 70kg x 8, 80kg x 5
Hmm fair enough, I only consider the first set to be a warm up and the next 2 to be "work".
Likewise though, If I was using the same weight on all 3 sets, and going 8, 8, 5 (or 5 5 3 in your example) would you then do a few more reps at the same weight to get the full 8 (5) reps up or would you add weight to push through that plateau?
The question is what to do when the endurance isn't there, that it,s you have the power to move the weight, but would like to move it more times in one go rather than stopping/starting.
What I've done in the past is move the final set weight to the second set and added weight for the last set above what I was doing before.
Since you pointed out the whole MORE thing, I now completely understand why any sets at lighter weight prior to your working sets are a waste of time. I like to do one set at a fairly bitch weight just to see if there's any joint/muscle issues before I push out the working set, but only now do I truly realise that anything short of your working weight is doing nothing but burning calories (unless you push to ridiculous failure reps or something). It won't be promoting any kind of growth since it's not MORE.
IMO (as per your example Markos) - 60x 5-8; then 80x 5,5,5,3,3,etc to however many you wanna go lol. But no point wasting energy on the initial sets, since it's just calories that could've been put towards pushing MORE than last session.
My thoughts exactly, I get into working sets ASAP.
I take my sweet ass time coz I'm a big f**king girl.
Also Dan I dare say it depends on how many reps/sets you're aiming for, but regardless of whether it's 10x3 or 5x5 - whatever the max weight you can manage those reps and sets at would be your working weight. Which you WILL increase next session. Failing that, you know what to do (more reps or another set :P)
If you like to ramp the weight up and reps down, which is fine if youre not interested in absolute strength gains, then a system I prefer is the pyramid but with "control" reps up and "everything you got" on the way down.
40kg x 5
60kg x 5
80kg x 5
100kg x 5
80kg x 11
60kg x 12
40kg x 12
Too many reps, take too long as I do a full body routine 3x a week so 3 sets is about all I have time for on each thing.
Squat, Bench, DL, Bent Row, Weighted Chins, Weighted Dips.
3x8 with 2min breaks takes about an hour.
Would there be much benefit in going 3x5 and going heavier? I'm happy to get stronger, but not looking to get any bigger or heavier (I have a race suit and seat that I need to fit in). I realise calorie intake is part of that.
Edited by ActionDan
But its NOT 3 x 8 if you only do 1-2 work sets, 3 sets with the same weight is the correct way, 1-2 sets is crap if youre not going to absolute positive failure every set, and I know youre not doing that because you train alone.
A couple of sets at 80% is not enough work to improve unfortunately
What does positive failure mean? I am going til failure on the 3rd and any subsequent sets.
That is, I know I won't make another rep but I go for it and fail out on the way back up (using bench as example)
Ok...
Well I'm going to regular people failure on every set at the highest weight I do I do as many sets as needed to ensure I've done at least 8 reps at that weight, for every exercise.
But I see that I'm better off doing one warmup set and doing all my sets at that weight.
Failure is a state of mind, too deep for this thread or forum even.
Is it the point where quite simply put, the muscles you're pushing just switch off? As I've only pushed to what I'd consider absolute failure once or twice, and as an example one of these occasions was dumbbell press - the point at which I failed, my left arm was going to absolute jelly, shaking like crazy etc etc, then after what seemed like a lifetime (probably a few seconds of barely moving up, but not going down), it felt as though my arm just switched off and went limp, causing me to bounce the 34kg DB off my chest lol
Is that absolute failure? I mean, as far as I'm concerned without proper mental training there was no way I was completing that rep.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 馃槓
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
