Birds as per your post in Leesh's build:
You mentioned that you don't believe that if you tried your 1RM before starting volume training that you wouldnt hit the same volume as if you did it the other way around due to muscles getting sore.
Yet you went on to say that 1RM at the end of your set can be in your opinion a testament to true strength (along these lines), but as per the above, if you are already stuffed from volume training then surely your 1 rep max weight is less then if you performed it just after a couple light warm ups.
I know you aren't after 1RMs or sole strength gains, but can you see how what you said doesn't make absolute sense? You contradicted yourself in basically the very next paragraph. Or did I miss something?
Hope that makes sense
Due to muscles tiring*
No I didn't say anything about it being a testament to true strength. All I said was, if you can do a 1RM after your volume training, you can do it at any time on and given day, even if you feel sick, when you haven't had the volume training to tire you out first. Of course I believe your 1RM will be higher before volume training.
Rather than contradicting myself, I was actually pointing out the contradiction that you thought I had made: people say that volume is completely unaffected by doing 1RM prior to it, but that 1RM is affected by volume prior to it. I argue that you can't have one and not the other.
sorry mate, misread the paragraph.
I agree with your point.
If you have been busting your balls every workout and then change the workout to go for a 1RM at the beginning rather then at the end, then something has got to give.
If you do a 1rm at the beginning of the workout and push out an extra 10,20,30kg (whatever) and then hit the same volume levels in the same set and rep scheme (or even improve it) then something is drastically wrong.
My opinion though.
Yep that's true.
And before anyone jumps in (because I always have to disclaimer anything I say in here), I'm not saying that doing 1RM at the end of your volume training is the best way to increase your strength. The traditional method is to do your heavy singles after a warm up and then follow up with your volume training .
really depends on your end goal.
Trent @ PTC told me to do 1RM's every 3 months just to see where I am at strength wise
as an indication not a definitive this is the be all and end all or to get stronger, just as an indicator
Edited by -FIGJAM-
Good article; it says an elongated version of what I say on here every few weeks or so when I get sick of reading the unnecessarily pedantic questions about the 99% or someone's latest idea to achieve the 1% when they haven't even got the 99 yet.
Actually on second read I notice no mention of steroids, yet being IFBB and looking at the dude it's hard to believe he wouldn't be using; not that I don't agree with all he's written, but it's kind of interesting to see no mention of it with regards to training and recovery etc.
I like the part where he says Troy should be eating complex carbs like pasta and bread :P
Since when was bread a complex carb (in most cases, given white bread is most popular)? I thought it was a shitty carb lol....either way, I do eat carbs. Far too much lately.
Interesting to be is the part about push/pull/legs.
I've always done full bodies 3x weekly (well not lately but usually) but I've contemplated if I'd be better splitting like that.
For anyone else who does that sort of split, what sort of exercises are you doing to fill an hour?
Before leg and back issues I was doing, squat, bench, DL, bent rows, weighted chins, weighted dips in that order.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
