Sounds about right to me, but out of the mentioned movements all I really focus on is the clean and press, I am trying to learn to snatch but I am finding it a very hard movement to pull off.
Hence the only real clarification from me would be in the clean and press, well the press part any way, with a mil press the bar is pressed up but slightly forward, with the clean and press the press ends with the bar straight up and the head pushed forward with the shoulders pushed back (head through the window)like a clean and jerk.
Well at least this is how I was taught to do it, I firmly believe this is the best full body movement there is, others may differ but it is my fav, it smashes me and makes me puff.
Yes I'm a fan boy, plus it scares most of the gym plebs away from the rack area where they do their concentration curls for the girls,LOL.
Clean then military press for reps is an old favorite of mine. It's good to know you can pick the weight up off the ground as opposed to from a shoulder height rack. I haven't done it seriouslyt since a single attempt earlier this year , 105kg for a few reps, vid on my training log.
The press is always head through the window style. Unless you are sitting on reclined bench or doing the 'bro' version behind the head.
  • Like 1
OK I need some clarification here on some lifts and what their goddamn f**king correct names are lol...I'll detail what I believe some they are, so just correct me if I'm wrong.
Clean
Loaded bar on ground > explosively lift bar and shrug it real high then get under it in to the bottom of a front squat position, then front squat it up to standing
Catch position of a Clean
Power clean
Same as clean, but starting from knee height a lighter weight that you can pull higher in the second phase of the lift and then a slight dip of the knees to get under it and catch it higher and then stand up.
Power clean catch position
Clean and jerk
As per clean above > Slight bend in the knees then press up through the legs hard and push the weight over head and drop to a lunge stance of sorts to get under the bar, while keeping the bar where it is to finish with it above your head and arms locked > move back to standing position
Clean and press
Same as clean and jerk, but final stage is a strict military/front overhead press from shoulder height rather than dropping your body under the bar
yep. but towards the end before it was removed from the olympics it kind of became more of a standing incline bench press.
Am I right?
Mostly
Edited by TTT
Read this in today's age for a bit of a laugh
http://www.theage.com.au/lifestyle/life/blogs/stark-naked/grunty-gym-bloke-its-time-to-shut-the-hell-up-20131113-2xfrd.html
I really couldn't care less if others grunted at the gym
Someone I know recently got banned from our gym for being too loud and doing 1RM's
Love this comment.
Omg, seriously??? If you don't like your testosterone gym, go some where else. There are now heaps of womens only gyms available. It really sounds like you are in the wrong gym. There is no need for over reacting. Also if you can't or don't want to join a womens only gym, there is also a thing called earphones. Whack one of them on, listen to your favourite tunes, and stop whining.
CommenterPaulo Location Date and time November 13th 2013, 11:17 pm
Yes ,some people really are very controlling ,and manipulative of others freedoms of expression ,arent they?
CommenterKane Location Date and time November 14th 2013, 7:12 am
    • I also built one, for a bit of a laugh. Pretty happy with it. Basically, obtained a clear garnish, painted it sanded back the paint off the letters, clear coated it. Inserted a 3cm EL strip through a slot I created in one end and sealed it up.
    • Apexi SAFC - AFC 1st Generation Rare Old School JDM As you can see it all lights up in the photos and is in 100% working condition. Has been kept in storage and boxed for years there won’t be to many like this if any! Especially with all original packaging and manual. price:$650   APEXi SAFC 2  In Complete Working Condition Refer To Photos and view the video provided.  Price:$500   Located Melbourne - Australia Wide Postage Available At Buyers Expense  IMG_6981.mov
    • wow so i just logged back in after buying the 33 and joining SAU, And I've got all a whole bunch of you wanting to know more, well unfortunately it still doesn't run i was hoping it was seized from a snapped timing belt as i turned it over by hand and it was fine and then it did a few revolutions and jammed solid when i was running it with the key, so the timing belt is mint, I've also found a lot of the parts I'm removing have already got bolts undone or not quiet tight enough to be unsuspicious. so the plan is to find a running RB30 block and chuck my head on it.  I have a habit of buying stuff I don't need or require so for my none running engine i have a forward facing plenum , Apexi power fc, 40mm Turbosmart wastegate, And for the car its self coilovers ,low seat rails and BRZ seats (black seats with red stitching i already had these and they are ADR Approved and allow rear passengers access)
    • I took apart the dash and found this strange 2 pin connector. it dosen't seem like its factory or oem, any clue on why someone would add it and where it might have been connected too?
