first the today tonight story, now this piece of "journalism" http://www.news.com.au/lifestyle/health/the-aussie-blokes-hooked-on-steroids/story-fneuzle5-1226781478429 , obviously fit people are the next target of the nanny state!
I stopped reading at this point
The NSW Health Department says the results you get from illegal steroids are disputable - some studies insist they work at boosting muscle mass, while other say they don't.
Really getting sick of seeing shitty journalists. How the fk do they get a job as a journalist when they can't even differentiate between "they're" and "their". That's grade 3 shit right there.
lol my mother told me I was too skinny in the waist the other day. Are people so used to the image of unfit and unhealthy people that it's become the norm and somewhat desirable...whilst a fit body appears to be the outcast? It must be steroids and a dangerous obsession, how else could they look better than me! Don't read beauty magazines, they will only make you feel guilty.
While we are on this topic, I'm sick of hearing people complain about how unfit or fat they are followed by "I don't have any time to exercise". This person has convinced themselves beyond reason that they are literally too busy in a 16 hour day to even go for a run; that there is no point in their day where they aren't doing something or couldn't push something aside for 10 minutes. Next day on their Facebook feed: omg Breaking Bad was so good lastnight!
I'm slowly thinning on top, must be the governments fault.
I'll take responsibility for this one, Dan. Because I can take it. Because I'm not your hero. I'm a silent guardian. A watchful protector. A Dark Knight.
I hate that person too, my response is always something along the lines of "Well it's not important enough to you yet".
I am no athlete and I will gym before I sit down to watch a movie or something, but that's just me as I enjoy some exercise.
When it's important enough, it just takes up the time of something less important and it fits in no worries.
That's very true and I will be using that line from now on instead of entering the special Olympics argument of actually trying to convince these stubborn assholes otherwise.
  • Like 1
haha touche
My favorite quote was from the Commando in the Biggest Loser
Something along the lines of:
Commando: What have you been doing all your life? Why haven't you exercised?
Contestant: I've been busy!
Commando: Busy what? Busy eating chocolate?
:woot:
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
