I'm slowly thinning on top, must be the governments fault.
Ain't nothin' slow about my thinning Yo.
This is a story all about how my life got flipped, turned upside down And I'd like to take a minute just sit right there, I'll tell you how I became the prince of a town called No-Hair
had a guy notice me doing cuban press, face pulls etc yesterday, gave me some good pointers with other prehab type exercises I could do (turned out to be a doctor).
Birds that sounds like something the pro BB in our gym would inflict onto one of his PT clients, except for the fact that he dosen't squat so it would be leg press and calf raises lol. how long did it take you to recover afterwards?
Not long til I could stand again, but my legs were cactus for the rest of the night. Dropped down from the pull-up bar and my legs had trouble standing back up etc.
I guess where this shit gets you bad, is that when you are squatting a big weight, your leg and back muscles will go until they can no longer push up another rep of that big weight - but that doesn't mean they don't have lots of strength left in them - just not enough for xxxkg. Hence you can stand easily afterwards under just your own weight. Drop it down to something light, like 60kg, and your last rep at this weight is more likely to drain you of any remaining strength, to the point where you can't support your own body weight for a minute or two. I imagine body squats with no bar would do you even worse.
Give it a shot sometime, after your heavy weights!
I used to think I could do that with 40kg, was trying to prove a point... got to 30 reps lol
Funny this, I don't remember you conceding your point to me; seemed to forget all about it :P
I really have no idea - the most I've done is 64 reps of bodyweight in the 8x8 setup for Tabata!
I tried it again lastnight with sets of 90kg. Back hates me today. Did better in squats lastnight than normally, so I'd say the huge set of 60kg helped somewhat.
Probably :)
But we know I'm too stubborn for that...and my old pb was based on a 1RM after working sets,
However I have switched my squats to that style (1RM before working sets), as they were actually on a severe plateau that I couldn't break through with any other way.
Probably :)
Birds, stubborn?
:whistling:
  • Like 1
Stubborn Birds got a 115 bench tonight, so another 5kg and we are home for a new pb :)
Though thinking about it I never used to touch chest; it was always within an inch of it, so I'm probably actually stronger than I used to be.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
