I might have an overly simplistic view or maybe my desired outcomes are just really easy to achieve because they are minor but for me it's as simple as when I want to gain weight or get bigger I do heavier weights and eat more protien/carbs etc and when I wanna lean off a little or drop weight I do a bit more cardio and cut back a little on the calories and that seems to work fine enough.
If you wanna drop 10kg, what are you doing to achieve it? I'd like to think you've already looked at your diet and tried to cut back on fats/sugars, unnecessary carbs etc, and that you're doing sufficient exercise for your calorie intake. That is, you should have a bit of a calorie deficit.
If you're doing those things, properly, you should be losing weight. If you're not losing weight then you're still eating too much or not exercising enough for what you eat so change it.
I totally agree with this. If someone is on the gear why do they feel they have to lie about it.
Well anabolic steroids are illegal, so those who do choose to take gear would be disinclined to admit their own usage of the drugs as they do not want to incriminate themselves by stating it outright.
Secondly, roids are generally frowned upon amongst the general public and is seen to be taboo to most due to the negative stigma portrayed by the media.
Lastly, for well known figures in the fitness/bodybuilding industry, admitting to steroid use can definitely ruin their chances of getting a sponsorship or even terminate their current sponsorship - once again due to the negative portrayal of steroids in the public.
There are more reasons why but those are the main ones in my opinion.
However, i think you'll find that if you ask the biggest guy in your gym in a private conversation, they will more than likely be open and honest about their steroid use.
I've recently adapted to arching my back with my legs tucked in tight (mimics decline) i.e. using more of the other muscles rather than relying on just shoulders to help you push. Decline you actually use chest, shoulders and tri's a lot more hence why you can lift more.
Don't my first squat session in a while since pissing off my patella tendon....Oh fark I'm screwed after only 1 set, which is 20kg less than last time. So much for all that riding at least helping maintain anything lol. Guess I must be riding the wrong bike amirite?
I've just been to the osteopath after squats aggravated my injury last night (on the right side, not my injured left side). Be careful Troy, it's not worth having a constant injury :(
I've pissed it off a couple of times in the past, just requires rest lol. Think I overdid it on the rest period this time coz I've gotten so into riding I just didn't care for leg day lol...was too sore most days anyway :D
ah yeah cool, well good luck with getting back into squats! :)
Has anyone had any success at naturally getting a decent six pack. Over eating 40% Protein; 40% Carb and 20% good fats - plus epic core workouts followed by lean protein shake for no massively appreciable gain. Helpful comment from someone that's done it would be appreciated :) I understand it's eating regime that achieves this result.
What do you class as an epic core work out?
roughly 45 mins twice a day - plank up, side plank, T-Stabilisation, Fitness ball Atomic Push-ups, fitness ball rollout, Mountain climber, V-Up, Wood Chop with fitness ball, Fitness ball Russian twists both reg and seated, leg raises, penguin crunches, - all sets of three with between 15 and 20 repetitions, others to fail and 2 min ergometer to fail.
My workout over the past few days in this holiday period using all the free time i can
Sunday:
4km Bike Ride in arvo
3.5km walk around the suburbs
3km run on the treadmill at the gym,
added on to that 9km bike to the gym and back
Monday:
3-4km Bike Ride Arvo
4km walk around the suburbs
Today:
25km bike ride to the inner city Melbourne, taking the train back
3.5 walk around the burbs
planning to gym later biking it and back
Edited by MrClandestine
That truly is an epic core workout, but it'll do little to get you a six pack...
    • As Duncan mentioned it's likely a remapped ECU, like the the one listed in the link I post earlier:  https://minkara.carview.co.jp/userid/444260/car/444612/2099320/parts.aspx He quoted 444PS with an unopened engine and twin GT2510s @ 1.1bar boost... sounds about right?
    • That’s great to know. I spent some time looking for info last night but had a hard time finding anything relevant
    • Ah ok the turbos looked standard when I had a look at the car. Didn’t look it was ever removed but very hard to tell. These are the best photos I have if it helps identify anything.    I know it’s basically impossible to see anything 😅
    • Its only a guess, but it likely doesn't have cams; probably a Z32 Air Flow Meter and slightly larger turbos. It was very common to chip and remap the standard ECU back in those days, but it means you won't be able to modify it further without replacing the ECU
    • Amazing! Thanks for sending this through. Feel safer knowing a reputable shop worked on the car before I decide to purchase.    Do you know much about how they would have tuned their cars through chips?    From what I know, the car sounds like it has very small cams, the usual exhaust and air filter mods and a chip in the stock ecu. Motor sounds healthy and starts right up with no hiccups or smoke, compression is around 140-145 cold (wasn’t able to test this while it was warm)
