Fair enough haha
Like birds said people aren't symmetrical, I ask about the arm thing because people overlook the most obvious stuff.
You'd be able to tell without measuring
Edited by r31slpr
Kate said my right hand sits lower than the left when standing, but that's the "low" shoulder.
Will have to measure.
Though I don't see how arm length affects how high the shoulder sits?
Or are you talking about discrepancies in length of bar travel in a movement, which makes sense but was not my original question.
Edited by ActionDan
Dan - have you had a spinal xray?
It's probably just not straight.
Mine is like a slight S bend.
My right shoulder hangs lower, further down my right hip is a little higher, making my right leg 5ml shorter.
You can't tell unless you really pay attention.
You can't do anything about it.
Apart from maybe run for local member of parliament.
I have never noticed this thread but so glad I have now haha
Anyway, anyone got some good exercises for traps? I struggle with getting some variety for my traps. Only thing I do is barbell shrugs, dumbell shrugs and upward rows.
farmer's walk, deadlift.
Has anyone tried 5/3/1 before? Thoughts on it? I was going to start it as my intermediate program, once I hit the 120kg bench and 200kg deadlift goals I currently have.
Ahhh I might give the farmers walk a crack. Looks like it's what I need. I need to deadlift but jsut can't figure it out and don't wanna put my back out haha
good for grip too. Only downside is the looks you get in the gym from carrying around dumbbells lol.
Haha yeah, that's the only thing I'm hesitant about. People will think I'm lost and can't find "my space" on the weights floor.
Yep. But not for long enough the last time I gave it a go.
Doing it again now for bench and OHP, Only at week 2.
It's great for some and not so much for others.
Give it a go and judge for yourself.
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
