oh don't get me wrong, confirmation bias and placebo effect are quite powerful things - the Mrs got talked into buying $200 worth of Yor Health BS supergreens, multivitamins and fibre supps by her PT for example.
Apparently a lot of people don't even respond to creatine. Most of the others are pure marketing garbage; if you were that serious about some of these "supplements" you'd just spend the same money on a cycle of gear and PCT.
I didn't know where to post this but as I haven't been able to squat or deadlift heavy this is my only joy at the moment lol
overhead strict press 80kg x 3... getting close to a bodyweight single
oh and mine are actually strict presses... not the ones you see dudes posting where they're clearly locking and unlocking their knees to drive the bar up... or leaning back so far it's a standing chest press lol
Bench going up as a result?
yeah I think so... will find out in a few weeks at a bench comp coming up... I got 4 x 125kg paused the other day... was meant to be 3 x 3 @125 but I got an extra rep on the last set... hoping for 145kg
I think there's a good carryover from overhead > incline > bench press... strong shoulders are a must for raw benching
lol
yep seated dumbbell overhead, flat bench dumbbell, incline barbell, overhead barbell, close grip barbell bench press, lateral raises and I use the Nautilus seated shoulder press/lateral combo thingy
Mitch: My best comp bench is 140kg but I only got 135 at the last comp which is why I totally revised my technique
got 132.5 x 2 paused today, fairly easy, looking good for 140+
  On 10/02/2014 at 9:12 PM, ActionDan said:
If you're doing CrossFit I'm sure we'll hear from you..
heart attack..........
wanted to try it and a living social deal came on that the gf sore so works out well
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
