Yeah I was trying it with the clean grip - I've never done cleans or any other Olympic lifts before either!
I'll try the arms crossed one, I thought it was bad for you though. Failing that, I'll invest in some straps, since the hand placement isn't an important part of the movement
Use a Smith machine to figure out which grip works for you. I'm going to start front squats soon and that's what I plan on doing first.
No way I'm going to try arms crossed with a barbell first time round. Might kill someone
Safety bar squats are somewhat similar to front squats in that the weight is out the front of you a bit. I am doing them at the moment because I have niggling ac joint issue and front squating with the bar on it in the rack position hurts.
Well an empty still weighs 20kgs and isn't restrained, so if you don't have it sitting right and it falls you could injure yourself or others I guess (and look like the tard that dropped a bar..)
Smith machine with 10 a side to start, once I get familiar with it move up to barbell.
Front squat focuses on the quad right?
Also, what program do you suggest to really stimulate calf growth? I'm finding that the arches of my feet start going before my calves so not getting the most out of it. I'm considering taking skipping back up to develop some conditioning on rest days and then high volume sets on leg day.
Comments?
another technique to stretch your arms out to improve front squats is:
assume the front squat position with arms under bar and elbows forward
have friend stand with their shoulders under your arms and slowly stand up
i get my mates to do it, main drawback is theyre both 6ft6 and im 5ft 10
sounds very broke back mountain.
which part is difficult boz?
Elbows up?
thoracic extension of the upper back?
shoulders not able to come forward enough?
video it
all fingers under is fine if you can.
but it requires more wrist flexibility.
the first 2 fingers makes it easier,
They are not there to hold the bar really.. just to anchor your hands somewhere so you can push the elbows UP.
and yes..
right up in to your throat.
I get my fingers where I want them, then the feet under, then swing one arm under, then the other as I put my head right back so the bar is right up against the part of my throat and clavicle meet.. then bring my head down.
as you stand up and have elbows up, the bar ends up sitting on your front delts rather than the clavicle.
then it's a big breath in, chest/elbows up, back arched, and squat down between the heels.
This shows where I mean by on the throat/clavicle.. ignore that his hands are not on the bar.
and what I mean by 2 fingers..
Edited by TTT
Its defs a fine line between cutting off air supply/blood flow and finding the right spot for the bar. If you find it hard to keep elbows up, wait til you start squatting with it.
I get just as mucg of an upper back workout as legs doing them.
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
