did front squats today - with the clean grip I was doing it wrong cause it was loading up my wrists, was much more manageable with arms crossed, but I think I might have had the bar sitting too far forward on the delts. Did manage to get 5x100 out though.
Wow that's alright!
What do you guys think about dynamic effort and max effort body programs? I've been suggested a new program.
Here is a copy of the program, I would have to take out shoulder press and delt cable pulls due to my injury though. Please let me know your thoughts, thank you.
Monday – Dynamic Effort Upper Body – Focus on speed not weight
Flat Bench Press – 8 sets x 3 reps @ 55%– Focus on speed not weight
Decline Bench Press – 8 sets x 3 reps @ 55% – Focus on speed not weight
TricepsPressdown – 3 sets x 12 reps
Seated Shoulder Press – 4 sets x 10 reps
Dumbbell Side Lateral Raises superset into Front Raises – 3 sets x 10 reps
LatPulldown – 4 sets x 10 reps
Rear Delt Cable Pulls – 3 sets x 12 reps
Wednesday – Max Effort Lower Body – Squat or Deadlift
Max Effort Exercise (Box Squat or Deadlift) – Work up to 90% and do 3 sets x 2 reps
Seated Leg Extension – 5 sets x 5 reps
Straight Leg Deadlift – 4 sets x 5 reps
Glute Ham Raise – 4 sets x as many as possible
Front Squats – 3 sets x 5 reps
Abs/Core Work
Friday – Max Effort Upper Body
Flat Bench Press – Work up to 90% and do 3 sets x 2 reps
Incline Bench Press – 5 sets x 5 reps
BodyoverTricepPressdown – 4 sets x 5 reps
French Press – 4 sets x 5 reps
Seated Shoulder Press – 4 sets x 5 reps
Bent over Barbell Row – 4 sets x 5 reps
T-Bar Row – 4 sets x 5 reps
Saturday – Dynamic Effort Lower Body – Squatand Deadlift
Box Squat – 8 sets x 3 reps – Focus on speed not weight
Deadlift - 8 sets x 3 reps – Focus on speed not weight
Good Mornings – 3 sets x 12 reps
Seated Leg Extension – 3 sets x 12 reps
Glute Ham Raise – 2 sets x as many as possible
Abs/Core Work
Edited by L33SH
I'm assuming that's 55% of your 1RM, which you'd have a loose idea of.
I like my exercise to be very simple so to me that's a bit too involved.
I'm also not keen on splits where if you miss one day for whatever reason you miss that work for a week - but I realise splitting allows greater targeting and emphasis which is great for those with a specific goal.
I'd have a thought a full body workout x times a week would be fine for you Leesh, as you seem to want general fitness, well being, and some nice aesthetics. OR are you now looking to be a fitness model or something?
Mitch beat me too it, just times anything you need by the percentage number with a decimal in front of it.
That chick is too muscular IMO, but if that's your goal then a split routine will likely be a must, as will excellent diet.
You can do it!
Thats your speed day and your meant to be moving the weight explosively to train the muscle fibres and neural system, its not to try and build muscle.
Do a bit of background reading on louie simmons westside method and itll help explain the ideas behind each day
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
