De-load week is weird, I know it is good for me but not lifting heavy seems weird.
Looking forward to month 2 of my new program.
I'm actually really enjoying the program, never more than about 45 minutes in the gym and my strength gains are going better than before when I was spending more than 1 hr in the gym.
I am a big fan of 5 3 1
Doing it right pays off, funny that.
If you are back to 76kg at 6'3, holy crap you must be skeletal now!
I'm skinny as shit. So much water weight and glycogen lost. At least some of it has been fat too. Have a serious 8 pack going on, but that's no good when you look like a strong wind would knock you over lol
+1 for spending 45 mins in the gym. 4 exercises for me, done twice a week, and I've never been as strong (or good looking :P).
But that was before I got sick lol
Do you have the deload every 4th week or are you going through 2 waves then deloading?
Ive heard the progress is slow but steady with 5/3/1, I might give it a try soon.
4 exercises? how many sets? full body or split?
I do squats and pull-ups Mondays and Thursdays, deadlifts and bench press Tuesdays and Fridays. About 6 sets per exercise, but I'll spend half an hour squatting and 15 minutes doing pull-ups for example.
I find it to be a good split that doesn't keep me in the gym all night, doesn't really overlap with DOMS or muscle fatigue, and it works all the major muscles in the body. About the only exercise I'd like to add to it is rows...and shoulder press, though I can't do any overhead work for the now.
Sometimes add in captains chair on deadlift day to hit the abs, but pull-ups does most of that.
But my doms is so bad from Monday (first workout in a month) that it's a two day week this week :(
Stumbling around the office like a war vet with a slug in each leg :(
De-load on the 4th week.
Option 1, 531, Normal, Boring but Big, Less Boring
Monday: Mil Press, Bench, Chins
Tuesday: Dead, Squat, Hang Leg Raise
Thursday: Bench, Mil Press, Row
Friday: Squat, Dead, Leg Curl.
Will go with the periodization bible when this cycle is over in about 5 months if I feel I need to mix it up a bit.
The time savings are from not doing pretty boy exercises and only focusing on compound exercises, the only machine I use is the Leg Curl thing.
I have just finished reading Starting Strength, good read and very motivational.
On a side note: The WHS Nazi's at work decided that the heave beam we have is a safety hazard because you might fall if you let go!!!!!, I kid you not, they then made us get a Skid Steer Loader and rip it down, WHS has got people so scared of any risk that they are now making up stupid shit.
I've been liking 5/3/1 too - I'm currently using the Simplest Strength template due to it having a programmed main assistance lift mostly - I've finished the first cycle and jumped straight into the second - I figured the deload was more for those who have been doing it for a while.
It is a slower rate of progression, as it's aimed at the intermediate to advanced lifter
By heave bar I mean heave bar/chin up bar/pullup bar, 6 of one 1/2 a dozen of the other.
To clarify what I call a heave is a overgrasp grip lowering all the way down and raising till my chest touches through bar.
It wasn't mounted to a wall it was a free standing wooden job made with 150 x 150 post and a 150 x 30 bolted to the top, it was 600mm buried into the ground with 3 baffles of cement in each post hole.
I was as solid as they come, I'll post a pick when I get home.
Negotiated with the boss for a longer lunch break to go gym. Only going to have 45min to work out and want to do some cardio as well as weights.
Anyone got any recommendations for a decent enough weights routine?
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
