I do bench press...
Day 1: squats, pull-ups
Day 2: deadlifts, bench
Chuck bicep curls at the end of day 2 if you like. You don't really need them if you're doing enough deadlifts.
That's about as complete as you'll get in the shortest time. I've got plenty of time on my hands but after trying this for the last 12 months I don't feel the need to bother with anything else. Keep it simple, stupid!
I have no idea what starting strength is...this is just what my program evolved into post shoulder injury to accommodate everything with as little shoulder interaction as possible. It started as a leg program in my days of not being able to move my arm much without pain, then evolved to include pull-ups and bench as the shoulder recovered somewhat.
Figjam, you could do 5/3/1 with minimum assistance too.
Starting Strength is
Workout A
3x5 Squat
3x5 Bench Press
1x5 Deadlift
Workout B
3x5 Squat
3x5 Press
5x3 Power cleans
Workouts A and B alternate on 3 non-consecutive days per week.
Edited by bozodos
Don't wanna argue with a famous program, but the OCD in me doesn't like the idea of doing exercises unevenly like that. I like the spacing of mine, the simplicity, the lack of overlap, the fact I'm in the gym 4 days a week which perfectly fits into the working week with a rest on Wednesday...the fact I'm stronger in all exercises just doing this for a 40 minute session than I was when I was in the gym for an hour and a half each time. Will be doing this program for a long time methinks.
I get minimal results, every month I only put a extra 2.5 kg per month on my bench and OHP and 5kg to my squats and deads, as I'm bad with math I don't know what that will equate to after 12 months.
Hang on, that's 30 kg for my bench and press and 60kg for my squats and deads.
So going from that and without having to do a deload due to stalling that would be going from my current 1 rep training maxes of 130 to 160 for bench, 80 to 110 for press, 180 to 240 for deads and 145 to 205 for squats.
One of the guys at work lifts competitively and has hassled me to have a go, I'm thinking of training smart for the next year and a half and then having a attempt at a comp, Ill be 50 then so it is a good motivational tool for me to use.
Slow and steady for the win is my new mantra.
I'm all for adding weight that way, slowly and steadily, but have to be realistic too...if you have a 160 bench within 12 months, up from 130, and haven't jumped on the juice I'll go HEY! Well done.
Having a structured program where I walk into the gym knowing how much down to which sets of plates that I'll use what I'll lift is the best IMO. I like having a squat assist on my deadlift day, a deadlift variant assist on squat day, and a bench assist on OHP day.
I do have mates who can't stand doing the same thing for more than 3 weeks in a row though, so I guess its horses for courses. Naturally I'm now stronger than them.
If I stall then I will deload on the exercise I'm stalling on, if I don't progress as fast as the program states then so be it, BUT, the program has a solution for it, deload and then keep going up.
My next goal is to push or pull what's written in my training log, soon I will be doing a PB for every exercise, even if its only 2.5kg.
I'm not looking to be the guy who lifts the most at the gym, I'm taking this as I do with my car and my job, with time and hard work I improve, when I stall I find the reason and fix the problem.
A good quote from Starting Strength is "3 steps forward, 1 step back".
Either way Im getting stronger which is a win.
Boz I 100% agree, lots of guys at the gyms I use focus on curls, forearms and calf raises and have no structured programs, they may have some "peaky" biceps but they are weak as piss on all the compound movements, they are the same guys dropping the weights when they dead 100kg because they don't have the strength to lower it.
Provided you have the genetics , diet and rest you should have a red hot go at this over 12months.
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
