Yeah I know what you mean, it took 9 months of weekly, fortnightly then monthly physio to get my infraspinatus healed. I still need to be really careful or it comes back. A new physio gave me an exercise for my current injury which just flared up my infraspinatus a few weeks ago :(
Currently I have a back hyperextension that has been around for a month, and still quite painful.
Hang in there soldiers. My shoulder injury from nearly 2 years ago has made amazing improvements over the last 12 months. Still gives me very minor inflammation, but nothing distracting. And I thought the healing was as good as it would get after the first 6 months. I even smashed my old pre-injury PB on bench only a few months ago. Some shit just takes a long time to heal, but many of these injuries can be come back from provided good rest and rehabilitation, healing the injury around mobility movements etc.
4 specialists couldn't find anything visibly or physically wrong in spite of some pretty painful inflammation, so after 6 months I had resigned myself to it being a lifelong injury for me. Not so! The body can do amazing things overtime, things that science is yet to touch on :)
lol
Nah, out of the 4 specialists I saw, the osteopath made the most sense...he had the same opinion as the others, but a better explanation that I understood. He used a skeleton model to explain the joints and what my ultrasounds actually meant. Said there was nothing wrong with my mobility; the pain and feeling of something being wrong was nothing serious or else we would see it on ultrasound; it was something my body would have to heal over time (which is what osteos tend to subscribe to); I have, for lack of an actual medical term, clicky joint syndrome, where my joints are looser in their sockets than they should be and this likely caused my shoulder injury - means I have to be very careful with weights and technique. So on his advice I just kept at rehab, slowly introducing more mobility as I went along and slowly increasing the loads as well as icing it when it was inflamed, and these days I get hardly any, if any, inflammation after using the shoulder. Low reps don't bother it, but high reps can. I still don't have as much flexibility as my other arm, but as long as I can push weights I don't care.
Well for me I have hurt both shoulders on incline bench and press in the past.
One guy reckons my shoulders roll inwards and my back isnt engaging them and keeping them straight. He believes that is why my bench has always sucked.
What he doesn't know is why it hurts on the computer, sleeping, throwing a tennis ball and a number of other activities.
Bad posture is also to blame I think. Will see what physio thinks tomorrow
Hypermobility?
Nah doubt it, my joints aren't that flexible, they are just loose so to speak...could pop out or dislocate easy etc.
I have no doubts what my shoulder injury started out with was the supraspinatus getting caught between moving bones / joints.
good news about my physio, he thinks that it is all posture related and can be fixed pretty quick.
major thing that I have to do is change my desk lay out at home and work, sit up straighter, walk taller and a few simple back stretches.
also said i have scoliosis (if that is how it is spell it) which is why it hurts more on my right side rather then my left.
unfortunate thing is I have to lift less, especially anything above my head
Time to swap out the M for a B in your name now.
But seriously, good news that it's minor. I can second the posture comment as it made a lot of difference for me to stand up staight/walker taller/sit better etc. Oh and bent rows or something that involve shoulder girdle contraction (for me) as my shoulders were rolling forward from too much bench.
Anyone have tips to build some thickness in the upper pecs, primarily just below the collar bone? The rest of the pecs seem to be filling out nicely but the upper portion are making very slow progress in comparison. Currently do the following exercies for upper pecs:
- Incline dumbell (~30-degree angle)
- Incline barbell bench press (~30-degree angle)
- Incline flyes (sometimes cable, sometimes dumbells) (~30-degree angle)
Someone mentioned adjusting the bench angle to about 45-50 degrees, but I have always been under the pretense that the higher angle results in more deltoid activation?
Edited by T.D
genetics.
depending who you talk to will depend on the answer. Some people believe that there is a difference between the upper and lower pec, others claim its all the one pec
whatever u do just make sure you smash the chest area and eat enough food for it to recover
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
