Bloating side will just be my shitty digestive system. I think it *may* be the creatine pulling too much water through into my guts lol.
But yeah, I definitely noticed more energy, focus, strength, etc from it. If I didn't get the sides I spoke of, and it wasn't bad to use a PWO all the time....I'd use it every session haha
I use pre workout every session, I also use creatine every day
Anyway to speed up tendon recovery?
Big weekend on the tools has proved costly. Skipped Monday because I was sore and pulled the pin towards the end of tonights session as the tendon from the back of my elbow to the top of my shoulder is killing me.
Felt mostly around the tricep elbow connection point.
tried the NO3X. The orange/pineapple once is the best tasting pre work out I have had. tastes like berocca.
Started loading up on the creatine as well. No real dramas there. had my 20g before dinner with no issues.
Now just to stick to this over the next 3-4 weeks that I have off
Can't hold squat bar in place without rotating shoulder to use arms = twinge.
Can't hold onto bar to dead without having load go through shoulder = twinge.
Bodyweight lunges maybe? Some swiss ball morning glory things (for back)?
Trying not to even use my arm to drive the car..
Front squats (either arms crossed or in rack position) - neither of these make your shoulder rotate externally.
Bent over BB rows hurt?
Have you tried doing squats with your hands right out at the edge?
or dropping your pinkies off the bar?
or thumb over instead of under..
  • Like 1
ActionDan what are you doing for shoulder rehab? Get some Therabands from a physio and maybe a lacrosse ball for "deep tissue massage", light dumbbells also work, for doing "lucky cats" (external shoulder rotations / rotator cuff exercise). Attach the theraband to a door handle or table leg and practise retracting your scapula then drawing your elbow back, keeping it close to the body... these are the sorts of things my physio got me doing after I damaged mine.
Nothing specific for rehab at the moment, just rest, some ice, and avoiding use until the general discomfort goes away.
Not sure if any of those movements will aggravate it TTT, Can give all these things a try though and see. Cheers
depending on what the issue is / exactly what causes the pain, you can find a way around it.
Front squats don't externally rotate the shoulder at all and that's the most common shoulder pain.
Hands out further will make it harder to keep the bar stable but means the shoulders rotate much less.
This shit is pretty good to with really light weight.
Ahh yeah I remember you giving me some good rotator cuff exercises last time (different shoulder issue).
This is, I think, the tendon between my elbow running up the back through the tricep and connecting to the bony point in the shoulder. Most notable at bony point now where as a few days ago most notable toward elbow.
I use maca powder, so good
Maca has to be the best natural supplement i have ever used and probably the only one i have noticed a difference with in a few days. Clear thinking and massive boost in libido. Its some good stuff thats for sure. 2 teaspoons in my oats or a milo with skim milk which i find the tastiest
  • Like 1
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
