Good news on my abdomen, it seems I only tore some muscles and not another hernia, no heavy lifting for a while though.
So today I started some GVT, day 1 was chest and middle back, 10 x 10 of DB bench followed but 1 arm row for mains.
As I haven't done a lot of volume for a while 100 reps of each although with a light weight I am feeling it now.
3 months of this should be interesting.
I'll drop in my program once I've been through it and am happy with it.
Sadly no squats, cleans or deads in it till my current injury is sorted.
I'm using 600mm step ups and RDL for legs if the guts can cope.
100 step ups should be interesting, I'm also waiting for Thursday when I'm meant to do 10 x 10 of heaves, I assume I will need more than 10 sets to get the 100 out.
Fun times ahead, LOL.
  • Like 2
Did some legs today against the doctors orders. Only did real light weight and made sure i had correct form. Only exercise that gave me a lot of grief was squats.
Have pulled up real tight. Will see how it is in the morning
Good news Bird, well done!
Here's my update.
I took random bathroom selfie to text Kate while she was out walking the dog (excuse facial expression, was not meant fo ryou guys).
Still missing a good 3-4kg, so I'm about half way there on what I lost way back when I hurt my back (still not squatting, only doing bike work) also carrying much more mid section fat as you can see (abs could be worse given my ab work consists of a few basisc planks for back strength and some swiss ball morning glory type things).
Still down on all lifts also after that shoulder strain which is sticking around a little but slowly getting better.
Could be a lot better but given my diet has suffered (not that it was ever specific for training but I tried to eat healthy, but with a child, work very busy,etc) and that I'm only getting 3x 30min sessions a week (including a good 10mins of bike) I am managing to maintain some shape at least.
  • Like 3
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
