Has anyone tried Musashi Bulk? Ive tried looking for reviews but can't seem to find any.
I'm considering buying some...
Yeah I have used it quite a bit in the past. I consider it a pretty "safe" protein powder, as in it won't really mess with my gut (no creatine), and it's made by a proven, mainstream manufacturer. I used to use it in conjunction with Musashi 92, depending on the time of day or if it coincided with my workout. The Bulk has carbs, so it's better for pre or immediately post workout, while the 92 has very few carbs so it's better as a supp before bed, in the morning if you know you're having carbs for breakfast, or just as an in-between-meals protein shot.
You can definitely get both of those cheaper online rather than through the shops.
LOL
No, but if it's a daily and you need to keep driving it you don't drive it at 100% WOT until you've fixed the miss...
I get your point, all I was saying is that I'll avoid those movements right now until I've had a chance to get into physio, have it assessed and continue with recovery steps, in the mean time I can at least get a little leg work in with some lunges without straining that nerve/muscle/whatever it is.
I've got a holiday starting this Friday so can give it some rest then, be lucky if I see the gym at the hotel twice while I'm away.
You didn't have to edit out Laser GLI and change for Meteor either, I got it the first time :D
Edited by ActionDan
Squat - The exercise = deep squat.
Squat - The event = hip crease below knee height.
If you are not a competing lifter lifting a massive weight for 1 single rep - squat all the way down
Do a test.
load up your bar with whatever you squat for 10 reps and do 3 sets of 10 reps to parallel.
next session to the same weight and sets x reps but squat deep.
It will be harder and you will feel soreness you didn't with the parallel squats.
Foot position is not so important.
what ever makes your knees feel OK.
generally, they will point outwards.. probably closer to 30 degreese that 45.
Both deep and not-so deep (parallel or just below) squats can work.
There is debate over which is safer but, basically either done right will give an equivalent development.
Well respected athletes and coaches on both sides of the methods. Arguments are mostly on which is less injury risk.
I've done and had training on both. I believe either can be done safely enough but, like an advanced driving course squats are much better experienced with a few expert lessons. Whatever the instructor shows you , do that. It all works, just not so well if you have been coached (term used loosely)by people with bad habits themselves.
You could start a whole thread on discussing them that's for sure.
Rack http://www.samsfitness.com.au/products/bench-presses--power-racks/powertec-power-rack
Bench http://www.samsfitness.com.au/products/benches/powertec-utility-bench
I'm not going to get around to setting it up until next week I reckon because I've just moved into my new home so I have a lot of other things to do (reason I haven't lifted/eat properly in over 2 months), lost 4kg....
I have weights and bar but I don't have a weight stack yet but will get one when I get around to it. I'm going to have the rack sitting on carpet, you reckon it's worth getting the matts for underneath?
Depends if you care about your carpets.
Rubber mats might also leave a stain on your carpets.
Dans idea of a carpet mat on top of the carpet might be a good idea.
If you give no fark for your carpets then don't bother.
Mine is outside on a stencilled concrete patio floor so I have rubbr mats even though my plates are rubber coated.
it protects both the floor and plates.
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
