especially as I've seen programs that get very specific, 77% 83% or whatever
What the hell kind of programs would tell you to work at 77% or 83% of your 1RM.. this is a great example of powerlifting/bodybuilding bro-science at it's finest. Your body isn't going to adapt to an exact percentage. You might as well work off of 80% because that extra 3% either way won't make a noticeable difference in strength or size gains.
For me, crafting the body into something most desirable for the opposite sex, is where it's at ;)
hahaha I guess I'm different due to being married... but for me it's about being allowed to keep my man card... I'm a graphic designer which apparently means I have to weigh 60kg, wear thick rimmed glasses, girls jeans and be into bicycles... fck that, after spending all day discussing the differences between 2 almost identical fonts and drinking macchiatos I like to go to the gym and do badass shit... I'm no PL but I like to lift heavy... nothing better than chucking serious weight on an Oly bar, sitting it on the ground then lifting it above your head
I was doing dips yesterday with a couple of the 24kg kettlebells hanging off a belt looking like a couple of giant black balls swinging between my legs... I felt pretty baws for a few minutes lol
its funny when I meet someone for the first time they pretty much always assume I'm a tradie.... until I show them my girly hands lol
On lean gains he reckons for an intermediate lifter
1.6 x bw - squat
1.2 x bw - bench
2 x bw - deadlift
This is a good starting point, a minimum if your serious
just gotta sort out my squats :S... stupid weak legs
i like to read the Scivation Books stuff. Currently working on their Tri Phase routine (slightly modified but I will more then likely go back to the original).
They have books on just about everything that is training.
http://www.scivationbooks.com/
I like to read this site called
www.itsnotrocketscience.com
Listen to your body, train what works best for you
This lol. Too many people looking for the easiest/fastest way to gain the most amount of muscle in as little time as possible, which kind of works contrary to what is actually required at the gym - a f**kload of effort to get what you want.
its not so much looking for the fastest way to achieve results, well not for me anyway. I learnt years ago there is no fast way.
I read this stuff because I find it remotely interesting. I also dont think that I am perfect so I like to see and hear other people's opinion on a range of subjects. There are always better ways of doing things, its just a matter of hearing them out and deciding if you agree or not.
My 2cents.
My 2cents.
Without artificial assistance you mean Mitch? Seem to see a whole bunch of huge teenage blokes in the gyms these days, partly they're starting at an age where their T is at a peak, but mostly a whole lot of them would be on the gear.
Interesting article in the SMH not long ago; not really 'news' , but interesting nonetheless - the 'steroid vacation' to Thailand: http://www.smh.com.a...0526-1zblt.html
    • Wiring the car up today so will report back for anyone else that searches this in future.
    • The light comes on from low oil pressure. Not temp. Did you do a rebuild or just add an ecu etc?  What oil are you using and where are you getting the pressure reading from
    • So like the title says my 97 rs4v has a oil temp sensor but no triple gauges as it was originally factory navigation. My current setup is not using the factory oil pressure sensor as I'm running a link ecu and a real sensor.  I did leave the oil temp sensor in. So now as I was working on first start up and bleeding coolant I get the oil light on the dash faintly as the oil temp gets to about 60-70c. Oil pressure is 45psi at idle at the same time.  I'm wondering if the temp sender doing this?
    • Well it runs again!  This was a definite case of while I have it apart lol Everything except the body and interior has been restored, refinished, or replaced.  @socal_stagea is my IG if you're bored and want to see all the pics.
    • I already got plug and play Link ecu G4X. Main concern is that the de loom works on s1 motor or not? I already rewired injector and coils loom to suit my bosch injectors and bosch vag coil. I’m not running any Iacv. For cas running the nz wiring kit i bought the neo plug one so it suits the wiring but don’t know it works or it doesn’t matter they work the same on every motor. For wastegate solenoid do i need to wire straight from ecu? What can i do for iat sensor to work or same run from ecu? For Vct solenoid, right now i got s1 vct solenoid on motor so do i need to remove neo connector and add s1 connector to work? Any other thing i missed i need to do to make the motor working on de loom. Any different mechanism on neo vs s1?
