Ok lets set this straight here instead of it being ridiculously all over the place.
REST TIMES DEPEND ON THE TYPE OF TRAINING YOU ARE DOING.
No 'ifs' 'buts' or 'maybes'
If you're resting more than 30 seconds in an endurance rep range work harder. If you're resting more than 90 seconds for hypertrophy work harder. If you can push out heavy strength-based sets one after another in less than 2-3 minutes, YOU'RE DOING IT WRONG
Is it possible to get stress fractures in your forearms from bench pressing? (I know this sounds retarded, but my forearms have been aching chronically for weeks now :S, and the only thing that's changed is I've been getting stronger and shifting more weight then I ever have before...)
Edited by GHOSTrun
Yeah, hate to admit it, but when I was reading a Zyzz interview he said he didn't do any oblique work because he was concerned it would make his mid section too big. Anyone shine some more light on it?
I always thought obliques just followed your body lines and being core muscles like abs, you're somewhat restricted on how they can affect the overall shape of your body. Maybe if you really built them up or you were shredded as fark they would affect it more.
Mine aren't far off the rib cage (see below; pic taken prior to my recent cut), so I don't think they play with my shape much. Even then, I'm stick thin in the waist and I've done too much lat work not to look like a pizza slice lol.
Where in the forearm does it hurt? Muscle or joint or bone? Is it getting worse?
generally your bones should increase with strength and density as you start lifting more. Someone correct me if im wrong but everytime you lift heavy small stress fractures develope, they then heal and become stronger.. we just dont feel fractures most of time
Do you do much isometrics?
whats your Calcium intake like and where do source do you get it from?
If you make a fist and look at your knuckles, from the wrist to halfway up forearm is where the pain is and slight swelling, bit sore to touch, no discolouration. Between this pain in both forearms and even worse chronic pain in my left elbow and shoulder, makes benching a nightmare for me. Might have to give it a rest and switch to military press for a while because the weight would be half of what I'm doing on bench and considerably less stress.
I'd say I don't get as much calcium as I used to because my consumption of milk has dropped a lot in the last few years, but my bone density has always been good in dexa scans so don't think that's an issue?
Edited by GHOSTrun
There are major tendons that run all the way from your fingers to the forearm muscle, is it possible you're mistaking these for bones? I'd put it down to technique, there's nothing else short of a seperate medical issue that should cause that. Have you tried different ways of holding the bar? Specifically, the angle of your hands...e.g. knuckles pointing at the ceiling, knuckles pointing behind you. The angle of your hand can make a big difference to stress on joints.
The fact you can lift heavy without issue on deads and squats suggests to me it's a technique issue, as your "bones" seem fine on those exercises no? May need to just rest it or cut back the weight and let your body catch up to it.
I know tendons and cartilage develop microtears and heal back stronger/bigger, I suppose it makes sense that bones do too Joey.
I have the same forearm pain from time to time, and it is definitely bone related.
Yes you do develop small fractures in the bone after heavy resistance workouts because in order for your bones to strengthen in density (so that they aren't crushed under heavy load) they must break down and rebuild just like muscle tissue. Basically you have osteoclasts which break down the bone, and then osteoblasts which are bone forming cells. This process of remodelling constantly occurs if you continue to participate in regular workouts, and this is all part of:
Wolff's Law
"...states that bone in a healthy person or animal will adapt to the loads it is placed under. If loading on a particular bone increases, the bone will remodel itself over time to become stronger to resist that sort of loading. The internal architecture of the trabeculae undergoes adaptive changes, followed by secondary changes to the external cortical portion of the bone, perhaps becoming thicker as a result. The converse is true as well: if the loading on a bone decreases, the bone will become weaker due to turnover, it is less metabolically costly to maintain and there is no stimulus for continued remodelling that is required to maintain bone mass."
In my opinion, I'd say that because during a bench press movement where your arms are directly under the path of gravity, it's more trauma on the bones in your arm (radius, ulna especially) when you really go heavy. A good way to see this for yourself is if you pick up two heavy dumbbells and lie on the floor with your arms flat out at 90 degrees. It's pretty painful and it feels as if all the weight is pressing down on your bones alone.
In response to Birds,
Your obliques and abs will grow in size as do any muscle, so yes, the more oblique work you do with added weight means it will take away from your V-taper slightly as your obliques tend to bulge and grow outwards like your lats.
If you choose to work them heaps, you just need to shed a lot more body fat to retain your V because that area is also quite a large fat deposit for the body (think "love handles")
you need to see a physio or equivalent... I have a bad left elbow that causes me trouble when I curl, row or pull up with palm supinated... I can train around it but your issues sound more serious than that... get it checked
Birds, keep training those obliques! the thought that someone would deliberately avoid strengthening a muscle so they appeared larger/stronger is just a tad retarded... I have huge respect for BBers and what they do but sometimes............ face palm
Edited by NickR33
Ghosty.
But use a broom stick.
It's the best thing for shoulders, chest, elbows, wrists.
Trust me I'm 35 and falling apart and this keeps me together a little longer.
I start right out the edges, and do 3 reps, then move in a little from both side and repeat till my traps are burning.
Do it every time you walk past the broom stick.
or at least before and after any training.
and during if you can between sets.
Ghosty.
Fark. This is exactly what I need to be doing. My shoulder flexibility is crap and seriously hinders not only my shoulder pressing movements but also benching, not to mention posture. Gonna go grab a broomstick from the shed this arvo.
I also read an article on TNation that lists Cuban Curls as a good way to strengthen the shoulder, which should lead to increased strength in pressing.
Like this, except the "upright row" part of the movement is 'optional'
have heard that working the obliques and deadlifts thicken the waist area which in turn makes the 'V' harder to get.
guess you have to decide what look you're after and go from there.
Also Birds out of interest can you post your routine (if you havent already)?
Also, reps range that you go for, rest between sets, rep times ie 3-1-3?
Edited by -FIGJAM-
Ghosty.
i will add that to my morning stretches. :cheers:
Yer only thing that's gonna make me give up woodchops is injury. As you know I'm going for looks over strength but I could never avoid training a useful muscle to make another part of me look big, that's just douchebaggery of the highest order. And now that I have visible obliques, I think the mid section would look plain without them anyway.
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
