havent had any personal experience with it..have you used any of those supplements before???
ive heard tribulus is suppose to be good but not really an idea about it.
figured purple wratth and protein ws doiing me good...plus decent diet mainly pasta and rice dishes & chicken :thumbsup:
Yeah i've used them before except triandrobol and trib, depends what you wanna do, i gained about 8 kgs in 4 weeks, i was on a 5 day program and low-carb diet. yes! lots of Chicken :D
shenq how old are you? trib doesnt work... unless your test levels are down, roughly 27yrs+
I'm 23, yeah i heard ups n downs about tribulus, most of them are downs lol, so i ditched that and got micronised creatine instead, it should go well with beta-alanine. triandrobol has about 60% trib terrestris in each tablet, and also high in steroidal saponins.
Yeah i've used them before except triandrobol and trib, depends what you wanna do, i gained about 8 kgs in 4 weeks, i was on a 5 day program and low-carb diet. yes! lots of Chicken :thumbsup:
Why would you be on a low carb diet if you are trying to gain weight? trib is a waste of money.
if the other supp your getting is from a supp store here in aus, most likely it probably wont work or will have very little gains. best thing to do is have a spot on diet, 60/40 protein/carb. for building mass, a good protein and a good creatine.. Most supps here in aus are crap compared to the stuff in the US. So save your cash unless you know someone who can get supps from the US :thumbsup:
you still gain weight when you on low carb mate, just need to maintain the right amount of serving carb per each portion, i.e i eat equivalent of 3 cups of rice or pasta per day.
You either bulk or you cut. You won't grow if you aren't having enough calories
From personal experiences, i gained at least 6-8 during my 8 weeks of training when i was on that diet. and not everyone is either bulk or cut lol
If you were replacing the missing carbs with fats then yeah i can see that you would grow a little. If you were on a 'low carb' diet (how low?) and weren't eating fats and STILL grew then you don't know how to diet properly lol
Well yeah fatty acid is essential part of the diet, like olive oil, avocado etc, each person has different physiques n figures, not everyone will work on a diet which would suit them the best, mate you if are struggling putting on weight maybe you should try a different diet n program
i dont have a progress shot... but i remember when the 2 points of bone on the top of my shoulders were sticking out.. and i hated it.. i noticed this morning that they are now surrounded by my delts and my traps.. im not huge... but thats progress right therr... same as my collarbones... they are now surrounded by my upper pecs.
Definately a bit of fat but not too much. You are always going to put on some fat when you are eating so many calories a day
how much of that 25kg would be muscle?
can you post up some before and after pics? I'm genuinely interested to see how you gained 25kgs in 12 months.
So your saying you built 2kg muscle / month for 12months?
If your happy with your results, congrats, I think I've built 15kg in the past 2-3 years if I'm lucky :blink:
But unless your on something illegal or your genetically special, that's not physically possible from what I can see, have a read of the truth about bulking
Although I'd still say your strength level is much much more important than kg/muscle. Who cares if you've got 30kg muscle, I'd rather be deadlifting 200kg (that's my goal for the year, not looking too good at the moment).
This was me before i even stepped foot into a gym, been that skinny size my whole life.
http://i27.tinypic.com/2gshbnr.jpg
http://i32.tinypic.com/2m50xhf.jpg
This was 4-6 months into training roughly
http://i44.tinypic.com/95ugrt.jpg
These pics were taken 1 and a half months ago
http://i26.tinypic.com/zn8p3m.jpg
http://i31.tinypic.com/14xnz15.jpg
    • Post up a showing a a wide RPM range, wastegate duty, timing, TPS, MAP Use 2x rows if you can, easier to read the data. Or just send it to me
    • This issue has been there between twins and singles… it ain’t the hot side.
    • This actually makes more sense than what I'm suggesting, which would make me feel happier anyway. I just reached for an idea on the cold side because the tests on the hot side theoretically ruled out WG problems. But now that you mention it, it did bother me that a 12 psi spring on what is supposed to be a good WG setup is on able to get down to 20 psi. That's bullshit. Read that way, that WG is not doing what it is supposed to.
    • If you have a valve, set to 12PSi, and when it ramps up, it goes out to 23PSi, and then settles for a consistent 20PSi and thats the lowest it will go, then I'd be suspecting you have an issue getting enough air to flow AROUND the turbo on the hot side. Now, this could directly flow into what GTSBoy is saying, and that's effectively that your skinny ports aren't able to get enough of the air through the head. Remember, boost isn't a measure of air flow, it's a measure of restriction. And if the turbo at max bypass around it is still able to deliver more air than the head can ingest, your boost will be up.   In the NEO Head, being NA, you said it's stock, are you on stock cams, and stock springs in it?   Have you tried doing a run with the wastegate held fully open start to finish?
